ZPOST
  TireRack
      03-09-2008, 07:41 PM   #1
MMMazing07
More than you can afford pal....ferrari
MMMazing07's Avatar
180
Drives: Z4M
interior xenon look (LED)
so i was bored this weekend and did full interior LED lights. I wasnt a fan of dull glow of the OE bulbs.
I put a white 6 figure LED in the footwells and the push button map lights. The 6 LED doesnt fit in the main map light so i used a single LED. But i will be getting a 4 LED this week that will hopefully fit.
The interior now has a nice sophisticated look to it now. More futuristic. And now i have much more lighting. Sorry dont have a pic. I will try to get one with my friend SLR.
ahmed
      03-09-2008, 08:02 PM   #2
BimmerZealot
61
Drives: 2019 BMW X3 xDrive30i
I put the blue glass halogen bulbs in my dome and map light assembly, get the job done. I tried it in the footwell but it was next to non-existent so I wired in two 12" CCFL lights instead, now my pedals have never been more visible =] Did you use side facing LEDs in the footwell assemblies? Cause the wedge bulbs sit sideways in the assembly so forward facing LEDs wouldn't produce enough downward light.
      03-10-2008, 08:06 AM   #3
Black///Mamba
Black///Mamba's Avatar
52
Drives: a beast
can you please post pics? i want to do this mod as well. where did you order the bulbs?
      03-10-2008, 09:15 AM   #4
Starscream
Starscream's Avatar
United Kingdom
135
Drives: ///M Roadster + E92 335i 6MT
pics and links to purchase request X2
Imola Red Roadster
      03-10-2008, 04:18 PM   #5
MMMazing07
MMMazing07's Avatar
180
Drives: Z4M
I dont have a pic. But basically it looks identical to this guys M3
http://www.m3forum.net/m3forum/showt...167680&page=15 (post #145)
I ordered them from v-leds.com . The bulb size is 194. The 6 LEDs fit in the footwells, map lights, trunk, and liscense plate. The middle maplight cant fit the 6 LED so i did a single LED from ebay. But im getting some 4 LEDs this week (hopefully it will fit).
      03-13-2008, 07:48 AM   #6
z33
Drives: z4
Guys,
I was told swapping to these LEDs can sometimes cause melting in the sockets or even 'check lights' to come on.
Pls advise.
Cheers,
Z
      03-13-2008, 10:18 AM   #7
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
i already did this like a while ago. FOOTWELL lighting is not standard on the Z. very nice to have and used the LED where it spreads out(Wide angle view) as oppose to normal LED"s which would have a "SPOT"
yellow-ness on the carpet...because of the carpet.
2022 GLE 53 Coupe
      03-13-2008, 01:33 PM   #8
BimmerZealot
61
LEDs run at a much cooler temperature then their halogen counterparts, they wont melt the socket at all. The bulb check light wont come on for the interior light, there is no check system for the interior lights. The headlights/sidemarkers, etc. do have a check system.
      03-13-2008, 02:12 PM   #9
Black///Mamba
52
Drives: a beast
is this an easy DIY? I am very nervous about doing anything to the M.
      03-13-2008, 04:02 PM   #10
BimmerZealot
61
It's a very easy DIY, if you can pull out a bulb and put in a new one you can do the install. The dome light bulbs may need a little sanding because the LEDs have a larger diameter but thats about the hardest part. Next hardest part is finding the right LED for each application.
      03-13-2008, 05:08 PM   #11
MMMazing07
MMMazing07's Avatar
180
Drives: Z4M
this is such an easy mod...........dont be worried about breaking anything.
BMWs are held togather by clips and screws.
      03-16-2008, 03:08 AM   #12
chicagobimmerboy
chicagobimmerboy's Avatar
Italy
77
Drives: Un esotico Italiano ;)
I like the lights accept that they dont flow with the BMW lighting, the cheezy orange glow from all the instruments and stuff
      03-16-2008, 09:37 PM   #13
BimmerZealot
61
Your interior lighting wouldn't be on anyways, EXCEPT while you're driving so it wont matter.
      03-16-2008, 09:46 PM   #14
BlackSapphireZ
97
yea and its EXCEPT in your sentence
2022 GLE 53 Coupe
      03-17-2008, 01:12 AM   #15
BimmerZealot
61
Oh, btw the 6-LED should fit in the center one you just have to install it in a reverse manner. You cant fit it through the hole from behind you can however remove the plastic cover over the center bulb and insert it that way it should fit just fine that way.
      06-03-2008, 09:30 AM   #16
jlstyle
jlstyle's Avatar
355
Drives: Porsche Panamera
2014 Audi S7  [0.00]
2015 BMW X5  [0.00]
So can i just take out my OE bulbs from dome light and bring it to any autoparts store to match specs with blue glassed halogen to replace?
      06-03-2008, 11:42 AM   #17
BimmerZealot
61
You wouldn't even need to do that, they are 194/168 wedge/peanut bulbs, you'll want the blue glassed ones. Most places sell a full kit for all the bulbs in the car as well.
      06-04-2008, 05:02 AM   #18
azndavid85
11
Drives: 2007 Z4 M coupe
How did you actually removed the plastic cover? I was not able to open it and didnt want to put too much force to push it out because thought it might break.
      06-04-2008, 07:57 AM   #19
MMMazing07
MMMazing07's Avatar
180
Drives: Z4M
just pop it out by sticking something in the edges and cranking in down. requires some force but it does come out.
zpost
