Installing LED bulbs in car without HID headlights
04-08-2016, 03:18 PM | #1 |
13
Rep 73
Is it possible to install these:
http://www.carhidkits.com/index.php?...FQJZhgodphUHEg in a 2011 328xi that has no HID headlight setup? Basically I just want to replace the regular h8/h11 bulbs with the led ones. Thanks for any response! Sorry if this has been posted before I'm using the iPhone app and it gave me an error when I searched. |
04-09-2016, 02:56 PM | #4 |
162
Rep 699
Drives: 2010 E90 BMW 328i
You can. You might get an error though.
Murdered 2010 E90 328i
ESS VT1+ | BMW PE | 3IM | K Sport Kontrol Pro |
04-09-2016, 05:16 PM | #5 |
Rep 33
it is possible to code out those errors if they do pop up when using led bulbs. i am planning to replace my H8 angel eye bulbs with LED lamps and code out the bulb check in the NFRM.
04-10-2016, 04:25 AM | #6 |
15
Rep 200
Drives: '09 E92 N54 335i
If you don't have Hids you can buy an aftermarket kit. Make sure it's "error free" or is "canbus" or comes with an "error cancellor/resistor". Do not make the mistake of buying an LED bulb. The light out put will be crap and you won't see anything. Get HIDS. less are completely different and are not suitable for headlight low beams.
E92 N54
JB4, MHD, Alpina flash, ARM DPs, Cobb CP/HKS bov, BMS DCI/OCV, PE exhaust, 2nd cat delete (vibrant 1792), Mishimoto FMIC, Fuel-It stage 2, Msport F30 N20 EWG |
04-14-2016, 09:48 AM | #8 |
3441
Rep 79,211
You will need to code and I don't know if those particular ones will have enough output.
I recommend an HID kit instead. HPB is good error free hid kit. No coding required for 2008+ vehicles. |
04-14-2016, 09:46 PM | #9 |
27
Rep 213
sorry jeff, i ve seen that you recommend a lot HID instead of LED due to the output it actually give, but my question to you, if i have a DEPO replacement as headlight h7 , am i going to blind or get a ticket from a cop?
04-15-2016, 08:29 AM | #10 | |
3441
Rep 79,211
I couldn't find in the listing the lumens output which is more important. I know HPB also sells LED low beam replacement upgrades. If you'd like I'd be more then happy to reach out to them to see what they recommend for a low beam application that is friendly in any housing. or I can pass you their email here at Sales@highperformancebulbs.com They are the experts and they will be able to tell you the best for your application. I'm going to assume that any option wherever you buy from still may require coding. |
