e90 320D brake discs, pads and rear caliper replacement
04-08-2016, 04:46 AM | #1 |
95
Rep 478
Guys for my e90 320D I need replace all these parts below:
Front brake discs and pads Rear discs and pads Wear sensors Rear brake caliper Rear brake hose One of my friends suggested I could buy all these parts on http://www.eurocarparts.com/ and get them fitted by a local garage. How do I know which parts exactly to order and is this a safe option? Thanks. Satish |
04-08-2016, 05:17 AM | #2 |
46
Rep 232
Hi Satish,
Euro Car Parts are one of the largest parts dealers in the UK, good prices and availability. You can use quidco.com and get a small cashback on online order (reserve and collect or deliver). Also if you place items in your basket, leave it a couple of days they'll send you a nice reminder and 15% off code I would personally stick to Brembo disks and pads if your looking to keep your car standard. They have a search panel on the site where you simply put your reg and then it simple shows you the relevant parts for your car. |
04-08-2016, 05:31 AM | #3 |
175
Rep 1,596
If your getting them fitted by a local garage, its probably worthwhile speaking to them first.
Its possible that they'll be able to get the bits cheaper than you can with their trade discount. It also minimises any hassle if they send the wrong parts etc, as the garage can just get straight back onto their supplier, whereas if you've supplied them the jobs on hold until you sort it out. If you price the bits up yourself on the site as explained above though, you'll have a ballpark figure to work with. If the garage are trying to charge more than you can get them for, then you can challenge it or buy them yourself. |
04-08-2016, 10:03 AM | #5 |
616
Rep 3,194
Drives: E92 325i MSport Coupe
Having had a number of issues with non-OEM discs and pads, my advice would be to get Jurid (OEM supplier and available from GSF I believe).
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
04-11-2016, 06:49 AM | #7 |
Rep 6
Drives: E90 335d 2006
For what it's worth, I've just put standard EBC discs on the front of my 335d with yellowstuff pads all round and no different. Stops on a 6 pence.
£40 cheaper than the £200 Eurocar parts wanted for two discs. Others are correct though, they will send you a 15% off code a few days later. |
04-12-2016, 03:29 AM | #8 |
95
Rep 478
All quote from Mr Clutch Reading for all below, looks like this is reasonable so thinking of getting this done, any comments?
Quote for the following items = 621.38 including VAT parts and labour. Front brake discs and pads Rear discs and pads Wear sensors Rear brake caliper Rear brake hose Brake fluid change |
04-12-2016, 03:32 AM | #9 | |
95
Rep 478
04-12-2016, 03:33 AM | #10 |
95
Rep 478
04-12-2016, 04:05 AM | #12 | |
95
Rep 478
If I buy all 4 pads, discs, one caliper Brembo, who do you think would be able to fit them? I live near Reading, I am just worried if I order these and they cant be fit? |
04-12-2016, 06:00 AM | #13 |
175
Rep 1,596
as i said earlier, price up the parts yourself on the web so you know what it all costs, then get some quotes and compare.
I replaced all the brakes on my 330d for just over £200 in parts. A caliper and hose might add a futher £100 or so. I got all my bits from Jason at All German Parts. It was Jurid and Febi bits IIRC. £300 in labour seems a little excessive to me, but will depend on the labour rate in your area etc. |
04-12-2016, 06:31 AM | #14 | |
95
Rep 478
