BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > stickiest setup on 193m !?
      04-07-2016, 09:19 AM   #1
Bours
166
Drives: 2011 335i x-drive LCI sedan
hey guys i have a set of 193m wheels which are 8 in front and and 8.5 in the back whats the widest tires combo could i fit in front and back and is it possible to run a near square fitment or i would have to buy a another set of rims ? whats the most agressive setup can i run with these rims on stock x drive suspension im tired of the oem 225 in front and 255 in the back its not grippy as much as i expected btw i have a 2011 335 e90 x drive thx
      04-07-2016, 09:29 AM   #2
Ravenseal
Ravenseal's Avatar
Drives: 2023 M2 6MT
Pilot Super Sports on 335/25R20
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is
      04-07-2016, 10:38 AM   #3
Antetokounmpo
Antetokounmpo's Avatar
Drives: E90 6MT FBO; '18 F150 Platinum
225/255 is really the widest you can go with those wheels. Technically, a 245 will fit on the 8'' but you'd then need a 275 for the rear and that is much too wide for a 8.5'' wide wheel. Just get some sticky tires. Brigestone RE11.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      04-07-2016, 10:59 AM   #4
Bours
166
ah ok that sucks thx for the info buddy !
      04-07-2016, 01:20 PM   #5
natedog7700
natedog7700's Avatar
660
Drives: 07 335i RB's 625whp
Dont bother, 255/225 is the widest you can go. Period. If you dont mind a sloppy steering feel then go slightly wider and have tons of sidewall flex. I would suggest getting a set of rear wheels and putting them on the front. Run non runflat summer tires 255 on all four.
      04-07-2016, 04:50 PM   #6
tlow98
2188
Drives: 2009 E91, 2014 F15 x35i
Re71 as sticky as you'll find
      04-07-2016, 05:24 PM   #7
Bours
166
how long they last ?
      04-07-2016, 05:31 PM   #8
tlow98
2188
Mileage or hours?
Prolly 10k miles.
      04-07-2016, 05:45 PM   #9
Antetokounmpo
I'd wouldn't DD them. RE11 are a much better DD.
      04-07-2016, 05:46 PM   #10
Bours
166
are they noisy ? comfortable ans how long did they last you im hesitating between michelin pss and bridgestone re 11 !
      04-07-2016, 05:55 PM   #11
Antetokounmpo
They'll last 1-1.5 summers and are noisy as hell. RE11 is a much friendlier tire.
      04-07-2016, 06:03 PM   #12
Miller335
291
Drives: 2007 E92
I run 265 PSS's in the rear with 10mm spacer and it will slightly rub over big high speed dips in the freeway.
With no spacers they didn't rub at all.
2007 E92 335 6MT w/335is clutch FBO MHD E60 Wedge map 49k miles
      04-07-2016, 06:15 PM   #13
Antetokounmpo
You can easily run bigger than 255 in the rear. Problem is, with his wheels he can't run any wider because xi needs with 1% diameters (larger in front) and 265 is definitely too wide for an 8.5 and 255 is much too wide for an 8''.
      04-07-2016, 06:21 PM   #14
Theconnman2
Theconnman2's Avatar
28
Drives: 09 335i Alpine White
This will be my second summer on my re71s, hoping that they will last to the end of the year. They are a relatively loud tire but as with most other things you get used to it (just added solid subframe mounts and diff mounts, so tire noise is the least of my concern). If you want a daily tire get pss.
      04-07-2016, 06:22 PM   #15
Bours
166
The pss are noisy as hell ? Whats the difference between re 11 and pss i mean you chose these over the pss ?
      04-07-2016, 06:23 PM   #16
Antetokounmpo
RE71r are noisy as hell. PSS are super quiet. RE11 is a bit louder but offer significantly more grip than a PSS. Of course sacrificing tire life.
      04-07-2016, 06:30 PM   #17
Miller335
291
Drives: 2007 E92
XI, right.
Didn't pick up on that.
      04-07-2016, 06:34 PM   #18
Bours
166
Ok now i get it thx buddy ill get the re11 i guess then
      04-08-2016, 02:58 PM   #19
tlow98
2188
Thought we were talking about the stickiest avail for street?
      04-08-2016, 04:23 PM   #20
Bours
166
do you guys i can run 235/265 with my 193m ? or its not really doable ?
      04-08-2016, 05:14 PM   #21
Joey911
Joey911's Avatar
Drives: 2011 E92 335i MT w/ M Sport
I run 235 265 in mine. But it's a RWD
      04-08-2016, 06:03 PM   #22
brocklanders
brocklanders's Avatar
106
Drives: the uno, mineral white
06 325  [0.00]
Why do you need 275? I had 235 and 265 on my e90, I didn't realize 265 wasn't recommended on an 8.5. If I were to do it over I would run 235 255, I would want 245 but I don't know that they won't rub. Also you need to go down to a 245/35 which now that I own a 1 series I know that limits your tire choices. So I would recommend 235/40 and 255/35 on an e9x with stock wheels.
