BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Safe to run different left and right front tires?
      04-05-2016, 06:12 PM   #1
JunkyardDogg
90
Drives: 2011 BMW 335is E92
Related to my recent front right flat tire, I was planning on replacing it with the same Continental DWS but it looks like they no longer make the 235/35/19's. Is it a problem to go with another brand of that size or do I need to replace both fronts?
      04-05-2016, 06:31 PM   #2
dannyhavok
133
Drives: '11 E90 328xi 6MT
You really don't want to have different levels of grip/traction on the same axle, I'd replace both.
      04-05-2016, 06:41 PM   #3
Gohan335i7
Drives: 335i
2010 335i  [10.00]
☝🏻️ What the above mentioned. Agreed.
      04-05-2016, 06:45 PM   #4
JunkyardDogg
90
Nm I found the size I need. So it's the same tire, but this will be new. The other tire has about 6K miles on it. Will this cause any issues?
      04-05-2016, 08:11 PM   #5
sea6speed
Drives: '10 335i Msport 6M / E34 535i
Probably not, though there will be a slight difference in traction and circumference. Not really noticeable unless the older tire had a lot of wear in 6K.
      04-05-2016, 08:55 PM   #6
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
No. But it is okay to run different right and left front tires.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
      04-05-2016, 09:39 PM   #7
Pierre Louis
Drives: 2016 535d
I did this with my current Michelin PSS's needing a new tire with about 6K on the other one. The car started to wander a bit. The best wheel alignment guy around here told me his BMW did the same thing. Its gotten less evident now that I've got a few more miles on it, but you may not like the instability. Maybe its because the PSS's are "twitchy" to begin with. I wouldn't go near a setup with different front left and right tires.
PL
      04-05-2016, 09:48 PM   #8
Ravenseal
Ravenseal's Avatar
Drives: 2023 M2 6MT
Nooooope
2023 G87 M2 - Toronto Red | 6MT | M HAS | CF Roof | BMW 826M Forged Wheels | Mishimoto Skid Plate | Active Autowerks Single Midpipe
Retired: 2022 M240i xDrive | 2021 Audi RS5 | 2019 Camaro 2SS 1LE 6MT | 2016 428i GC | 2011 BMW 335is
