335d uprated oil cooler
04-05-2016, 03:49 PM | #1 |
122
Rep 148
I have been seeing some high oil temps when doing track days and its limited the time I can actually drive the car hard. Does anyone know where to get one specifically for the 335d N57? Or would a universal one be fine, if so what fittings it is for the take off points? Also where would be the best place to plumb it in?
Sorry for the 101 questions but I can't find anything aftermarket that doesn't look pants. |
04-05-2016, 04:09 PM | #2 | |
63
Rep 296
Drives: E90 335d | i3 REx
I'm thinking of tracking my car soon and it would be helpful to know what to look for. Thanks!
2011 E90 335d M Sport | KW V3 | M3 Bits (arms/bushings/sways) | JBD | Apex ARC-8 w/PSS
2015 i3 REx | Solar Orange | Tera World | Tech |
04-05-2016, 04:26 PM | #3 |
122
Rep 148
Im seeing 120 degrees C, highest I recorded was 125C before backing right off to allow the car to cool. Id like to see no higher than 100 degrees Centigrade under hard track driving, I am planning on fitting a large oil cooler, bigger alloy rad and waterless coolant, hopefully then it will be fine.
04-05-2016, 06:00 PM | #4 | |
Curmudgeon and Pedant
690
Rep 3,489
04-06-2016, 12:37 AM | #5 |
870
Rep 2,615
Crazy, why do you say your E91 LCI has an N57? Thought they all had M57 in them.
For M57, what you are missing in yours is what is called an additional radiator. I think this comes on a hot climate version of the D, at least on the USA/CAN side. You can always add it to yours, I am sure it will not be hard. Or you can try adding in the same spot an oil to air cooler, like N54 has. Last edited by Yozh; 04-06-2016 at 12:44 AM.. |
04-06-2016, 01:13 AM | #6 | |
122
Rep 148
Engine wise, I have been told on numerous occasions its an N57. I thought it was an M57 but local indy and tuner have said its the N57. Aaron |
04-06-2016, 06:22 AM | #8 |
28
Rep 151
Wow to have this problem! I mostly use my car for such a short commute it barely gets up to temperature, I think I need a new main thermostat but will wait a few more weeks until the weather picks up to do it along with a EGR cooler delete, one less thing to go wrong and will release a tiny bit of space in that region.
04-07-2016, 01:23 AM | #10 |
870
Rep 2,615
04-08-2016, 02:33 PM | #12 | |
765
Rep 3,556
This is real simple to figure out. Go to realoem.com and put in last 7 of your VIN into the top box. Mine brings up engine type in far right column See attachment |
Tags |
335d oil cooler |
