What would you do if you overfilled your crankcase?
04-04-2016, 01:06 PM | #1 |
1705
Rep 14,829
a) drain the extra out
b) drive hard, until all the blue smoke goes away c) add more oil, because the motor only likes to have multiples of the correct amount? My choice is a. I did something really dumb on my other car and added a quart for no good reason, and so I was out there at 23:15 EST last night with my COB led worklight draining a qt. of oil out I don't think 1 qt. necessarily blows out your rear main, or front main, etc., or even froths up, but it was a peace of mind deal....what a moron..lol |
04-04-2016, 02:30 PM | #2 |
345
Rep 1,015
Had an 07 328xi and the oil level sensor failed. Kept telling me it needed oil, even when I knew it didn't.
Never overfilled it myself, but read horror stories at the time about people who just kept adding whenever it told them to........ Still think these cars should have old fashioned low tech dipsticks. Not everything needs to be computerized. |
04-04-2016, 02:38 PM | #3 | |
17
Rep 120
This electronic dipstick is bullshit |
04-04-2016, 02:41 PM | #4 | |
Maximus Decimus Meridius
1130
Rep 4,584
F30 335i Melbourne Red Metallic M-Sport Package |
04-04-2016, 02:43 PM | #5 |
17
Rep 120
So its probably the sensor and not the engine burning it? Because that amount would mean its basically flowing oil in there? Should I tell the mechanic that I think its the sensor or will he will find the reason?
04-04-2016, 02:50 PM | #6 |
1705
Rep 14,829
good luck getting it checked. imho one way to know for sure, say you do your oil change and put just over 6.5 qts in, and the electronic dipstick shows down a qt., you know the sensor is wrong.
My scenario, I removed my wheel to spray PB Blaster at the brake hose fitting. Decide to check the oil while the car is jacked up...holy sh** it's down a quart! Fill it up. Then start thinking, whoa, that's probably because the RF of the vehicle is jacked up, not that it's really low. When I dropped it, yep, it's over max, by the distance of the H and L i.e. range. Stupid. I was gonna leave it and then get this bright idea at 11 PM that I better drain a quart out |
04-04-2016, 03:10 PM | #7 |
453
Rep 2,973
One extra probably won't hurt, but don't take my advise.
Had an E30 M3 where it was recommended to run +1. Car suffered from oil starvation on hard rights. Either get a baffled oil pan or run the extra quart.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
04-04-2016, 03:17 PM | #8 |
158
Rep 3,158
If I were a bettin' man, I'd say that ~1 quart over is right at the limit of what would be...."okay"....to live with in our ~7 quart oiling systems.
You'd probably see excessive oil consumption for a while as you have increased blow-by, but I'd think you wouldn't have main seal issues. Of course, this is just a thought experiment; it's not MY car with the extra quart floating around in it.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain |
04-04-2016, 03:44 PM | #9 |
95
Rep 308
Drives: 2011 335d M-Sport, Nav/Blinds
Reminds me of a story with a Geo Prizm I once owned. Had a coupon for an oil change at a place I had never used before. Took the car there about a half hour before closing time on Friday, and they changed the oil, and I paid and left. Driving away, I noticed a little hesitation and thought that was weird.... A few blocks later, I noticed EXTREME levels of white smoke coming from my car !! So I whipped back over there, and they were already closed - but luckily, two employees were sitting in the parking lot bullsh@tting. Told them my story, and turns out that TWO of them had added oil to the car !! It had almost 8 qts in there !! They drained it, refilled it, and the car was never the worse for wear.
But for OP, personally, for me, if this were my car, I'd drain the extra and get the level correct. |
04-05-2016, 07:27 AM | #11 | ||
319
Rep 891
Formerly Ian_N54 - @b1mmr
04-05-2016, 07:55 AM | #12 | |
1705
Rep 14,829
But since many of us DIY a lot of things, imho the best course of action is to remove the excess, just makes a person feel dumb a) wasting good oil b) wasting labor on something like that But there are worse things in life, and draining the oil out buys peace of mind... |
04-06-2016, 05:33 AM | #13 |
17317
Rep 18,740
You can always just drain the oil into a clean pan, remeasure 7 quarts and pour the used oil back in the engine.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
04-06-2016, 07:03 AM | #14 |
1705
Rep 14,829
True, I tried to do that with the coolant when I replaced my Nissan's radiator, because the system had just been flushed 5 mos. prior....but it got messy and I gave up....and now that pan is used for oil, meaning I only have 2 drain pans that are for used oil....
04-06-2016, 07:33 AM | #15 |
149
Rep 460
Our 335i is doing the same thing. A new sensor is around $190.00 which is ridiculous. There are no oil leaks so it's either burning a ton of oil which I doubt since there is smoke coming out of the exhaust or it's the sensor.
This weekend I'm going to jack up the car and check to make sure the connection to the sensor on the oil pan hasn't come loose somehow. |
04-07-2016, 06:32 AM | #16 | |
319
Rep 891
04-07-2016, 03:41 PM | #17 |
107
Rep 485
True story....
When brought my E90 home the first thing I did was drain the oil. I bought it at a salvage action and it had been in a front end collision. You never know what you're going to get at the auctions. Anyway, I put a drain pan under there and take off the drain plug. Oil comes rushing out and was still flowing quickly as the pan was nearing the top. So I ran across the garage and grabbed another pan. The oil finally stopped draining when that pan was nearly full. I didn't even know what size pan I was using so I look on the side and it says 7qt. So nearly 14qts of oil drained out of that N52. The valve cover and oil pan were both leaking at the time. I don't know if both failed due to being overfilled, or if it was over filled because they were leaking. After changing those gaskets, and replacing the entire CCV system, the engine has ran fine. It did seem to burn a lot of oil in the first 3000 miles after I put it back on the road but now that seems to have tapered off. So, I wouldn't worry too much about a 1qt overfill. It's not good to overfill any engine but I can say for certain an N52 will still be ok after running 14qts but I have no way of knowing how many miles it might have been driven like that.
2006 E90 325i Sparkling Graphite Metallic
2009 E93 335i Montego Blau 2011 F10 535i Sophistograu Metallic |
