TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Is It OK To Mix Oil Brands?
      04-04-2016, 08:51 AM   #1
bobkat09
bobkat09's Avatar
152
Drives: 2023 M240i RWD
I'm switching oil brands from Mobil 1 0w40 to Castro Edge 0w40 and have a couple of quarts of M1 left. Is it ok to use 6 quarts of the Castro and 1 quart of M1 together? They are the same viscosity.
      04-04-2016, 11:07 AM   #2
bavarianride
1509
Drives: bimmer
Maybe just keep the M1 as top-off oil?
      04-04-2016, 11:53 AM   #3
Kolyan2k
922
Drives: 2006 S2000
You can mix viscosity as well, nothing gonna happen to engine obviously. And with 1 quart left it can be an olive oil....
      04-04-2016, 12:38 PM   #4
John 070
1705
Drives: 335i cpe
I say no worries...if me, I would just want it to be LL-01....others don't care, probably doesn't even matter....
      04-04-2016, 12:41 PM   #5
StevenY.
///M
StevenY.'s Avatar
Drives: 10' SG e92 335i
Same situation as you except I have 4 quarts of M1 from last year. Guess I will mix with castrol 0w40?
      04-04-2016, 02:35 PM   #6
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
Drives: F30 335i
Don't do it, your car's going to self implode..!!
j/k you'll be fine..
F30 335i
Melbourne Red Metallic
M-Sport Package
      04-04-2016, 02:42 PM   #7
Needbmwpartzz
Needbmwpartzz's Avatar
851
Drives: 2009 bmw 328i x-drive
It's ok.....just don't add if the oil has sand in it.
      04-04-2016, 03:12 PM   #8
Kolyan2k
922
Drives: 2006 S2000
Ps. My dad added 1qt of tranny fluid to engine..... Still nothing happened....not that I was worried or anything.
      04-04-2016, 03:45 PM   #9
barefootin
barefootin's Avatar
63
Drives: e91
This my friend is what we call a back yard Hill Billy Mechanic fix for cleaning coaking, gook, and gunk from internal engine components. Works surprisingly well to quiet sticking lifters also.... The down side is the plugged pick up screen/tube, oil starvation, and bearing damage. Especially if the engine was a victim of poor PM or design flaws in the PCV system.
I tore apart a Audi engine that suffered this ill fate many years ago... I never saw such pretty colours in metal! The crank and rods were scored beyond description and to the inside of the journals the crank was literally iridescent shades of blues, reds, and purple.... Needless to say, I never went past pan removal after seeing that before informing the gent he had nothing but a 5cyl paper weight.
To the original OP... Mix away....
      04-04-2016, 03:50 PM   #10
hassmaschine
Drives: "NBO" 330i
tranny fluid is just oil with a lot of detergents & additives. I mean, don't fill your whole engine with it, but it's common to run a quart through an old gummed up engine to clean it out a bit.
      04-04-2016, 09:08 PM   #11
twinboost_MD
twinboost_MD's Avatar
Drives: AW 135i
your good
