Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > air condition failed 06 320d
      04-04-2016, 05:03 AM   #1
elroy443
7
Drives: e90 3 series
Just looking for some help guys, I started my 3 series this morning and the air conditioning wasn't working at all, I can hear the vents moving inside which I adjust the gauges but no hot or cold air. I've googled a lot and obviously the fuse could be at fault but I'm unsure which one to pull/are the spare fuses the unlisted ones in the diagram?
any help would be greatly appreciated
      04-04-2016, 09:33 AM   #2
9352e90
9352e90's Avatar
Drives: f10 535i, e90 325i, e70 X5
Is the blower motor itself out? Common issue on the e90's. The windshield weather-seal design can allow water to leek into the car and drip on the blow motor causing it to short out. Common issue, if you don't hear the fan running this is probably the problem. Check the fuse and the resistor first.
A timely example;
http://www.e90post.com/forums/showthread.php?t=1240645
