Anyone seen/know of these?
04-03-2016, 11:27 PM | #1 |
26
Rep 122
I'm looking for some form of dual cone intake (DCI) that'll sit behind my kidney grilles. I figured it might be hard to explain what I mean so I took to Photoshop and rendered up the image below to accurately show what I'm talking about. Anyone done this or is there a kit? Excuse my ignorance if this has been brought up before.
View post on imgur.com p/s that's not my car, nor my image. Just a random google image. Last edited by collinc14; 04-03-2016 at 11:29 PM.. Reason: info |
04-03-2016, 11:32 PM | #2 |
104
Rep 288
If you live in a desert, this may work but if not rain/snow/spit will be problems. Search for Mr5 intake
Ar Catless DP, MHD Flash, BMS DCI, ER FMIC, ER CP, Forged DVs
04-03-2016, 11:37 PM | #3 |
26
Rep 122
No problems here, I live in southern California so I'm not too worried about the elements, more worried about getting cooler air (I have BMS DCI at the moment)
04-04-2016, 01:07 AM | #6 |
75
Rep 853
And you would block part of the top radiator also ??? So if you have a stepped intercooler also blocks rad and now filters ??? I personally wouldn't relocate filters their as I'm sure there is some r&d behind Bmw building the car all grooves and openings for a reason
04-04-2016, 05:55 AM | #11 |
654
Rep 946
04-04-2016, 05:56 AM | #12 |
898
Rep 6,285
04-04-2016, 05:57 AM | #13 |
654
Rep 946
It's an interesting idea, but essentially you're just moving the filters ahead in the intake tract. You could achieve the same thing by leaving the filters in the same place and coming up with an intake snorkel. You'd still pull air from the same place but the filters would be better protected and easier to access for cleaning.
04-04-2016, 11:07 AM | #14 | |
MT or bust!
170
Rep 289
Drives: 2010 E90 335i M Sport, 6MT
2010 E90 335i M Sport, MT - BMW PE; VRSF 7in HD; RB PCV; VRSF CP; Turbosmart KPB BOV; M3 Cowl; VRSF Cerakote DPs; Carly coding; ECS Scoops; Ziza interior LEDs; Fuel-It! Bucketless; Diff lock down brace V2; MHD E60 Map from BQ; Mishimoto OCC; Fuel-It! Ethanol Sensor; Apex 18x9 ARC-8's; StopTech slotted rotors; HPS pads; ECS brake lines; MMP turbos, inlets, outlets; 034 mounts; Kumho PS31s; BimmerLife coils
04-04-2016, 11:19 AM | #15 |
3441
Rep 79,211
We offer that solution.
You just need an M3/M4 first and Maximum PSI Intake : ) On a serious note. BQ has done some thorough intake testing. So far the new AFE momentum GT looks the promising. Closed sealed box intake, using stock snorkel. |
04-04-2016, 11:25 AM | #16 | |
1904
Rep 6,968
Drives: 2007 Black/Black 335i e90
Cold Air is better
just don't see the point of adding more hot air to an already hot engine from its turbo chargers adding additional heat. If you really want to do it right, add a better inner cooler, charge pipe and then add a more efficient CAI such as ECS's version or AFE's. Both are enclosed just like the OEM version but offer more cold air flow to the engine, which maximizes HP. |
04-04-2016, 11:34 AM | #17 |
132
Rep 573
thats going to be a looong intake. 4-5 feet of piping from the rear turbo. If is just for looks go for it but i don't see any performance gains from this. I'm installing VRSF inlets they look sick and the sounds is even better.
04-04-2016, 12:19 PM | #18 |
26
Rep 122
Thanks everyone for the info, I'm probably just gunna grab some air scoops to put behind the grilles. On a kind of unrelated note, has anyone custom made a box to house the BMS DCI? it wouldn't seem to difficult to make(3D printing or carbon fiber) and I'd be very willing to purchase.
04-04-2016, 01:37 PM | #19 | |
654
Rep 946
04-04-2016, 03:00 PM | #20 |
30
Rep 142
Your going to need some thing like this to reroute the intakes to the front. Its somewhat of a similar concept to Mr.5 as mentioned above.
http://www.amazon.com/Spectre-Perfor...lexible+intake |
04-05-2016, 09:42 PM | #22 | |
110
Rep 1,340
