e93 Adaptive Headlight Error and No Passenger Light
04-03-2016, 12:50 PM | #1 |
7
Rep 37
A few months ago I was getting pretty bad condensation in my passenger headlight. I was busy and didn't have time to address it for a while. Eventually I got an adaptive headlight error and my passenger low beam would not turn on.
Took the housing apart and all of the modules at the bottom of the housing were filled with water. I bought a used set of modules on eBay, installed, the only difference is now the projector pans left and right but makes grinding noises, it seems to be miscalibrated. I still get the adaptive error and the bulb refuses to light. I'd like to get the adaptive working but I don't want to spend more money doing so. For now I just have it coded out and that error is gone. But my passenger side low beam still does not light while on the passenger side. If I plug the passenger side housing into the driver side plug then the light works and everything is normal. So I don't think it is a problem with the housing, ballast, or bulb. Angel eyes, cornering light, ambers, turn signal, high beam shield all work just not the headlight bulb. My main goal right now is getting the passenger side bulb to light then maybe getting the adaptive bs working again. Anyone have any ideas what is causing this issue? I can't go to the dealer, I'm CPO but I've painted the insides of the headlights and they obviously won't cover that. Thanks guys |
04-03-2016, 12:57 PM | #4 | |
4338
Rep 6,196
04-03-2016, 09:55 PM | #5 |
7
Rep 37
Thank you for pointing me in the right direction. I had to code two things and now it's working 100%. For anyone's future reference:
First. Default the RSMC module. Second if the headlight isn't turning on. See this post. The short circuit protection has been tripped and needs reset with Tool32. |
