M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > To all Coders- Get your hands on an M2 and code away!
      04-02-2016, 02:59 PM   #1
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
Getting my E90 coded was one of the most useful "mods" I had done to my car...
I know the M2 community may be smaller in volume, but we will not lack enthusiasm..
-c
2016 BMW M2/LBB/6MT/Exec Pkg
2009 Acura MDX-stock
2008 Acura RDX-stock
2005 Honda S2000-mostly stock
1994 Nissan 300ZX Twin Turbo-barely stock
      04-04-2016, 07:09 PM   #2
Twix
Twix's Avatar
657
Drives: 2011 e91
I'm really only interested in useful things, like the fake exhaust in the cabin. That has to come off.
Most of the codes should be standard 2er codes.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      04-06-2016, 05:21 AM   #3
MR.
MR.'s Avatar
4398
Drives: BMW M2 CSL Turbomeister
Can we do this ourselves or is it paying for a program to install on your laptop and buying a ODB?
I think pulling the ASD cable from my HK ampilifier will be easier :P
MR
      04-07-2016, 07:29 PM   #4
tux2005
234
Drives: 2017 M2
Has long as you have a laptop capable of running Windows on it (WinXP or 7 are preferred I believe) then you can do it yourself. In the 2Addicts forums you can post asking for the necessary software and you'll probably get a PM pretty quick with links to download ESys and the latest psdzdata. Then it's a matter of buying a cable off ebay or the like or you may be able to make yourself one.
http://www.2addicts.com/forums/showthread.php?t=997749 is probably the best place to start. I would expect the M2 is going to be rather similar to the other F22/23s.
I've got ESys running on a Win7 VM on my MacBook Air and have used it to code my 228i, hopefully will do the same with my M2 next year
      04-10-2016, 08:09 AM   #5
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
TY
      04-10-2016, 09:04 AM   #6
supersam
Da Baus
supersam's Avatar
283
Drives: F87 6MT, RA, E46
There are also many coders in the NE Tri-state area that you can travel to for a reasonable price. All of whom have plenty of experience with F platform. bimmerscoding.com is a sponsor here
http://f87.bimmerpost.com/forums/sho...d.php?t=965895
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
      04-18-2016, 08:07 AM   #7
zenmaster
Drives: '17 M2
Enthusiasm for ridiculous pita to simply change default software values.
      04-18-2016, 08:17 AM   #8
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
I'm not exactly sure what your comment is implying...but I found coding my E90 to be of tremendous convenience. Did away with the silly warning sign every time the iDrive started. My mirrors folded in coordination with doors locking and unlocking. The Alpina flash for AT's was a noticeable improvement. I liked having my gauges lit all the time. Little things, but it all added up..
-c
Dav3948.50
      04-18-2016, 08:04 PM   #9
zenmaster
Drives: '17 M2
It's BS and overly complicated to do it.
      04-18-2016, 10:11 PM   #10
confusion
confusion's Avatar
Drives: 2016 M2
Thus paying someone else is worth it?
      04-18-2016, 10:19 PM   #11
zenmaster
Drives: '17 M2
Depends on how much they are asking and for what options vs your cost for the tools, and how many times you'd actually use them.
      04-18-2016, 10:24 PM   #12
confusion
confusion's Avatar
Drives: 2016 M2
Do you know what tools are necessary?
      04-18-2016, 10:28 PM   #13
zenmaster
Drives: '17 M2
      04-18-2016, 10:29 PM   #14
confusion
confusion's Avatar
Drives: 2016 M2
Awesome, thanks.
      05-31-2016, 09:12 PM   #15
DKX4///M
DKX4///M's Avatar
Drives: 2020 X4M CS
2020 BMW X4M CS  [0.00]
2016 BMW M2  [0.00]
2011 BMW M3  [0.00]
F series works off a TCIP system, rather than D+KAN....No OBDII to ethernet cable ans e-sys, and data or know how to extract and modify existing data...
Im a beginner...But i had a pro coder try to code out ASD and he made it clear you cant...U can change the sound or make it a little queiter but not turn it off or down enough.
Ive read about just unplugging the ASD amp on HK systems...That works on some cars, not M2...Trust me I tried. Its integrated and the sound in is fiber opt....
Technik harness is only option.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3
      06-05-2016, 09:14 AM   #16
Shankska
Shankska's Avatar
Drives: 2019 BMW M2 Competition
2019 BMW M2 Comp  [0.00]
2016 BMW M2  [0.00]
2014 BMW M235i  [0.00]
I just coded my M2. I am on that 2addicts thread quite a bit. I had an M235i before. Everything coded is pretty similar to F22.
Couple things I coded -
  • Remove idrive disclaimer
  • Disable seatbelt alerts
  • disable seatbelt icon in dash
  • Roll windows up/down via FOB
  • Roll windows up via Comfort access
  • Fold/unfold mirrors via FOB and comfort access
  • Disabled side amber lights (blinkers still function)
  • Increased halo brightness from factory 8% to 100%
  • Close windows on rain detection
  • LED under doors handles on reverse
  • Disabled headlight washers
  • Enable video playback while driving
  • GPS sync for clock
Also - apparently you can disable ASD via coding - parameter = Model Range in the ASD ECU change from F87 to F020/F021
Not sure if this works or not. I guess I cannot hear, because I never notice the ASD. Also like to drive with the windows down.
And that is correct. F series communicate via TCP/IP over OBD to RJ45. I also have a DKAN cable, I have coded numerous E series as well. Completely different. Requires different software and cable.
2019 F87 M2C, Long Beach Blue, Exec, 6MT
2016 F87 M2 - Sold 9/2018
2014 F22 M235i - Sold 5/2016.
      06-05-2016, 10:23 AM   #17
supersam
Da Baus
supersam's Avatar
283
Anyone have success in getting the dash backlighting to remain on during the day?
      06-05-2016, 10:49 AM   #18
pup73
pup73's Avatar
517
Drives: 2016 BMW M2
"codemycar.com", the guy I used, is aware of the issue; he said he's going to work on it; perhaps if more people inquire, someone can crack it..
-c
      06-05-2016, 01:09 PM   #19
zenmaster
Drives: '17 M2
Originally Posted by Shankska View Post
[*]Increased halo brightness from factory 8% to 100%
How much would this reduce lifetime?
      06-05-2016, 11:35 PM   #20
fatumpsch
52
Drives: 2016 BSM M2, 6MT, exec
other codes
Congrats on coding. Sounds like some nice features. How much brighter are the lights? Were there any other codes available to chose from? I'd like to remove auto blip, turn music off with car, a single door pull to unlock and open door, and have car start in same drive mode that it was last in.
Any idea if any of if these options exist yet? I'd love to see a master list. There are probably other things that I haven't even thought of that I'd select.
Does anyone know how long it usually takes the coding community to get a good handle on a new model? thanks all
      06-06-2016, 10:37 AM   #21
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
Yes I would assume. Obviously this is hours of usage.
DRLs run at 100%, so this is only halos/lights at night. So depends how much you use that part. I dont drive at night.... that much in this car.
      06-06-2016, 10:53 AM   #22
Shankska
Shankska's Avatar
2016 BMW M2  [0.00]
thanks. there is a list on the thread on 2addicts posted above.
what is auto blip?
You can turn music off when you open door.
You can code to unlock door at shutoff - only requires one pull instead of 2
Cannot change start mode. No one figured that out yet. I think you can do comfort or eco. So no sport yet
m2
