F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Tire Size & Speed calculations
proTUNING Freaks
      04-01-2016, 03:08 PM   #1
LUV335
Drives: 2012 F30 335i MPPK
I am curious to learn how tire size, if at all, affects speed,distance, traction, stability control etc. calculations.
If I have 18s and go to 20s how does the computer calculate the correct speed? How would the car know that with bigger wheels every revolution covers a little more distance? There is ~11.1% more distance covered per revolution just based on going from a rim size of 18 to 20.
      04-01-2016, 03:24 PM   #2
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
With larger wheels the tire profile is reduced, which means that the overall tire diameter is kept almost the same.
The tire profile is reduced by 5% for every inch in wheel diameter increase.
For example for 225 tires:
225/45-18, tire diameter 25.9"
225/40-19, tire diameter 26.1"
225/35-20, tire diameter 26.2"
      04-03-2016, 08:31 PM   #3
LUV335
Thanks. So I guess one has to be careful in choosing the tire and rim size to keep the overall diameter the same? If overall diameter is different it will effect the speed and distance calculations?
      04-03-2016, 09:36 PM   #4
oln08
Drives: '19 M2
Check this out. Much easier than doing your own calculations.
https://www.rimsntires.com/specspro.jsp
      04-07-2016, 02:07 PM   #5
E30toF30
122
Drives: 2016 528i Executive Edition
The tire/wheel shop should be able to easily help you find the right combination of wheel and tires so that you maintain as close to stock spec as possible (or do it yourself with that online calculator in the link above).
Anything within 3% of the original overall diameter is considered acceptable and and somewhat within spec.
      04-08-2016, 08:57 AM   #6
Rudy@tirerack
Moderator
123
Drives: rudy@tirerack.com
Yes, the overall diameter is what is most important. When you make the wheel larger, you will make the tire lower profile. As long you keep the overall diameter close, your vehicle will not notice the difference.
Keep in mind, lower profile tires will ride stiffer and you will have to steer clear of potholes as the lower profile tires do not provide as much protection.
f30post
