Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Car moving around when stationary and engine started...
      04-01-2016, 12:32 PM   #1
Soul_Glo
Soul_Glo's Avatar
Drives: G20
It's like the car is shaking on a windy day when stationary. Only happens at start up and sometimes when idling in traffic/stationary.
Is this engine mounts?
I'm at 102K miles.
Any recommendations on mounts?
Expensive? Easy to DIY?
Thanks
      04-01-2016, 04:52 PM   #2
Aragorn30d
175
Drives: E90 330d
Mine does something like that sometimes when started from cold in very cold weather. Its a missfire, in my case caused by a duff glow plug. Goes away after a few seconds once the cylinder comes online.
Given yours is a petrol, i presume its a spark or injector issue?
      04-01-2016, 05:47 PM   #3
Terryk
Terryk's Avatar
United Kingdom
26
Drives: F30 mineral grey N47 ed
spark plug or ignition coil and then if not check for injector failure
      04-04-2016, 03:29 AM   #4
abeardo83
abeardo83's Avatar
United Kingdom
96
Drives: E92 M3
2008 BMW M3  [0.00]
Not sure it is a spark or coil failure. My 335i does it and it's had new coils, spark plugs and a walnut blast. It's probably the engine mounts. Not sure how easy they are to replace though, sorry.
      04-04-2016, 05:26 AM   #5
The0pportunist
The0pportunist's Avatar
United Kingdom
471
Drives: F30 335i
Are spark plug/injector/coilpack issues picked up with carly app?
Thanks
      04-04-2016, 05:34 AM   #6
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
With ethanol in fuel these days the volatility can not be ideal for cold starts. Shaking should disappear once warm if this is the issue.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      04-04-2016, 08:15 AM   #7
DriverLDN
DriverLDN's Avatar
United Kingdom
50
Drives: BMW 330i M Sport E90 2006
I had this same issue on my E90 330i about a month ago. I ran the tank down, filled up some Redex in it and then filled it up again. It's been running perfect since.
      04-04-2016, 08:56 AM   #8
AWSAWS
AWSAWS's Avatar
283
I've not read great reviews about redex. They seem to suggest it's just red dyed kerosene.
Miles are fairly high op. Might be a good time to look at new plugs and coils.
Coils are £27 each for good Bosch ones and plugs are probably a fiver each for OEM Bosch ones.
      04-05-2016, 12:44 PM   #9
Soul_Glo
Soul_Glo's Avatar
Drives: G20
Thanks. I guess I need to hook it up and do some data logging to see if there is actually a misfire. Will have to wait to the weekend.
      04-06-2016, 09:18 AM   #10
AWSAWS
AWSAWS's Avatar
283
A misfire usually triggers the Check Engine Light.
I did post a video. If I can find it i'll add it here. This was soon after fitting down pipes and I don't think my car was adapted for them yet. Whatever the issue was it seemed to resolve itself.
Maybe do a lamda reset of adaptations if you can.
