6 Disc Dvd Changer Installation Help!
04-01-2016, 06:48 AM | #1 |
8
Rep 114
Dear all!
Can someone please help me to decide and guide me in the right direction as to which method of connecting the power cables for the DVD changer is better? The DVD power cord comes with 3 wires 1) Constant power (B+) 2) ACC power (ignition on power) 3) Ground Method A: 1) Connect the constant power to the positive terminal of the battery directly. 2) Connect the ACC power to one of ACC IGNITION ON fuse slots in the fuse box Pro: DVD CHANGER will retain its memory functionality Con: DVD changer might drain the battery in the near future (was told numerous horrible stories about cd/DVD changer drain out car battery. Method B: 1) combine/join both ACC POWER/CONSTANT POWER and connect them to the positive terminal of the battery 2) Install a 2-way switch (on/off) in between DVD AND the battery so that DVD changer remains power off mode when not in use. Pros: Will not fear that my battery might be drained out one day Cons: loss of memory functionality Really need your advice/opinion on this! Thanks for reading my post
2010 E91 320D LCI ALPINE WHITE, PERFORMANCE POWER KIT, PERFORMANCE BRAKE KITS, OEM M3 MIRROR WITH POWER FOLDING OPTION, M AERO PACKAGE, PERFORMANCE FRONT BUMPER CARBON FIBER LIPS N REAR CARBON FIBER DIFFUSER, FULL CARBON FIBER INTERIOR TRIM KIT, KONI 1130 W/ H&R SPORTS SPRING,
EISENMANN RACE EXHAUST, OEM 19" WHEEL STYLE 230 & M225 Last edited by bennyyko2013; 04-01-2016 at 07:22 AM.. |
04-01-2016, 06:54 AM | #2 |
8
Rep 114
Yellow wire=constant power 12V
Red wire=ACC ignition power 12v
EISENMANN RACE EXHAUST, OEM 19" WHEEL STYLE 230 & M225 |
04-01-2016, 12:24 PM | #3 |
13361
Rep 7,484
Method A for the win. Mine has been installed since 2012 and never run the battery down. Besides you should tender your battery now and again if you don't drive your car often enough.
