TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > Lightbulb warnings
      04-01-2016, 02:15 AM   #1
abeardo83
abeardo83's Avatar
United Kingdom
96
Drives: E92 M3
2008 BMW M3  [0.00]
Lightbulb warnings
The other half came home last night with a face like thunder because her e90 was throwing all sorts of error codes for her lights:
cc id 89 (dipped main beam right failure)
cc id 122 (indicator front right failure)
cc id 125 (indicator rear right failure)
cc id 128 (left high beam failure)
cc id 129 (rear fog light failure)
cc id 131 (parking light left front failure)
cc id 133 (right rear light failure)
The only ones that aren't working are the left parking light and the right rear light. Any idea why they would all go nuts? Indicators are going wild too.
Thanks
      04-01-2016, 05:03 AM   #2
Aragorn30d
175
Drives: E90 330d
Problem with the FRM perhaps?
      04-01-2016, 02:02 PM   #3
vtwin_man
vtwin_man's Avatar
United Kingdom
37
Drives: G01 X3
Lights
Hi
I recently had a similar nightmare... I ended up changing the rear bulb holders and cleared the fault codes with a Carly coder. All fine now. They're prone to corroding and are cheap from BMW. My issue was soldered in faulty bulbs, but that's another story...
Pull them out and check for corrosion around the bulb fittings. Incidentally, my car showed faults with the front lights when the issue was at the rear.
      04-01-2016, 02:07 PM   #4
abeardo83
abeardo83's Avatar
United Kingdom
96
Drives: E92 M3
2008 BMW M3  [0.00]
Auto electrician says it's the FRM. Does anyone know where to get them? Or what they actually do?
Dead FRM on the e90 and now a dead e92 as well. Today hasn't been a good day.
      04-01-2016, 05:51 PM   #5
Terryk
Terryk's Avatar
United Kingdom
26
Drives: F30 mineral grey N47 ed
you might be able to find used ones. but they need coding for your car . also be sure to buy same frm as yours because there are several versions i.e. frm2 frm3
