TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Technical Forum > JB4 installed and major issues..
      03-31-2016, 09:41 AM   #1
walkerE90
United Kingdom
Drives: E92 335i Hartge
Hi guys
Installed JB4 today the newest version, ran car on map 5 as I have catless downpipes and DCI. Automatic
When driving my EML came on with following codes:
P0087- fuel rail/system pressure- too low
P0192- fuel rail pressure sensor circuit A low
P0301- cylinder 1 misfire detected
Reset them and off I went again, gave it some throttle and changing up gears and whilst changing it was jurking not selecting gear on autobox, then the dreaded transmission sign came on and the car seemed to be stuck in a certain gear.. Pulled over turned ignition off waited and started her back up, transmission symbol away and I can now select all the gears. Took it back up motorway then it shat itself coming up with P0301 cylinder 1 misfire and it was juddering when accelerating..
Any help or input greatly appreciated.
I have since reset codes and put map to 0 all is fine.
My gear oil was changed in the auto box recently car is at 73k miles..
      03-31-2016, 09:44 AM   #2
Fez335i
10
Drives: Blue E92 335i
In terms of the misfire, I'd check the coils.. You can swap them around to see if its faulty.. Personally I just changed all 6 coils when I had a misfire..
And change all 6 spark plugs...
      03-31-2016, 09:47 AM   #3
walkerE90
United Kingdom
Yeah I've read that could be the issue. Where and what coil and plugs to get.
Gearbox making me worried?
      03-31-2016, 09:55 AM   #4
TBN54
427
Drives: 08' E92 335 -> 17' F30 340i
First thing a lot of folks would recommend is to replace all ignition coils and spark plugs prior to doing the JB4 install.
JB4 will technically speed up the rate of the things in your car are not up to par (so to say).
      03-31-2016, 10:01 AM   #5
walkerE90
United Kingdom
How can you tell if the clutch is going on a automatic ?
      03-31-2016, 10:54 AM   #6
AWSAWS
AWSAWS's Avatar
283
Drives: E92 GC Turbos, FBO, 335i DCT
Before you do any of this stuff mate ensure you have up to date firmware on the JB4.
Make sure your default settings are correct and that FOL isn't set too high.
Check duty bias and AFR settings.
I doubt you have issues yet. I may be wrong.
Maybe start off on map 1 as it's less aggressive than the auto learning map 5.
GC Turbos, FBO, JB4, DCT, Port Meth injection, BMS Charge Pipe, NGK plugs. EBC brakes and pads, LED Angel lights, LED foglights, LCI rears OCC, Braided brake lines. Custom Diff Lockdown Kit, VTT inlets, TMAP, stage 2+ fuel pump
11.79@119mph (stock turbos)
11.74@129mph (GC Turbos)
      03-31-2016, 10:57 AM   #7
Aragorn30d
175
Drives: E90 330d
An automatic doesnt have a clutch.
you've given us engine codes, but what fault codes were in the transmission ECU?
      03-31-2016, 10:59 AM   #8
AWSAWS
AWSAWS's Avatar
283
Looks like it could all relate to the FOL value. Lack of fuel. Misfire.
Easy to happen on a JB4 with incorrect settings.
      03-31-2016, 11:28 AM   #9
walkerE90
United Kingdom
No codes on transmission it was literally the transmission symbol I plugged in and no relevant codes.. No clutch in automatics?
      03-31-2016, 11:30 AM   #10
walkerE90
United Kingdom
It's JB4 with latest G5 software. It's a box I recently purchased from eBay and apparently only 4 months old
      03-31-2016, 02:54 PM   #11
walkerE90
United Kingdom
https://sayyarti.wordpress.com/2015/01/20/everything-about-your-zf-automatic-transmission-issues/
Pretty sure there is a clutch mate of sorts
      03-31-2016, 03:14 PM   #12
Aragorn30d
175
Drives: E90 330d
Theres a torque converter between the engine and box in the position of the clutch on a manual car.
They dont really wear out though.
      03-31-2016, 03:17 PM   #13
joshe92
joshe92's Avatar
Drives: 2017 F80 M3
Make sure you get bosch plugs. Do Not get the denso ones
Look up German Auto supply on ebay. They sell them for the lowest I've seen
2017 F80 M3 competition Sakhir Orange: // ER catless downpipes, // AA EL midpipe resonated, // MHD tune
Retired: E92 335i MSport Sapphire black: // aFe intake // Remus quad // AR Downpipe, Secondary cat delete // MHD // BMW PPK // Alpina B3 Flash // Vrsf 5" Stepped IC & CP
      03-31-2016, 04:30 PM   #14
RajB
RajB's Avatar
448
Drives: E92 335i
I agree with AWSAWS in checking your JB4 settings and making sure you are definitely up to date with the software. As you say you bought it off eBay and the seller states it's only 4 months old but can't be 100% sure.
Certainly seems strange it's all ok in Map0 if their were more fundamental issues with coils etc.
E92 335i / M3 Hybrid - The Build
      03-31-2016, 04:30 PM   #15
walkerE90
United Kingdom
Just got Bosch coils and Bosch spark plugs from euro car parts spark plugs same as what real OEM quote, coils are the silver banded ones took a bit of a guess as they had other Bosch but black banded. Used the EASTER20 code and got all sets for £169
      03-31-2016, 04:32 PM   #16
walkerE90
United Kingdom
Appreciate the advice, it also came with the connection cable but I'm unsure on how to check the pre mentioned can you point me in the right direction and also what I need to look out for.. Really would appreciate it. Thankyou
      03-31-2016, 04:35 PM   #17
walkerE90
United Kingdom
Thankyou appreciate the advice. Is there a link for how I can check the above that you've mentioned, it has the cable so I believe I can plug from jb4 to laptop Thankyou
      03-31-2016, 04:45 PM   #18
RajB
RajB's Avatar
448
Drives: E92 335i
Basically check THIS THREAD out for all the info needed to install the interface software onto a Windows laptop etc.
Once you install it you can use the cable to check everything on your JB4 and the version numbers etc.
      03-31-2016, 04:55 PM   #19
walkerE90
United Kingdom
Great man thanks so much hopefully get to the bottom of it all
      03-31-2016, 05:38 PM   #20
AWSAWS
AWSAWS's Avatar
283
Hang on, are you actually running a diesel 325D?
Do you have a JB4 or JBD?
I'm thinking you've not updated your 'drives' status to a 335i?
      03-31-2016, 05:48 PM   #21
walkerE90
United Kingdom
It's 335i mate thanks for pointing that out
      04-01-2016, 07:08 AM   #22
walkerE90
United Kingdom
I've had the car scanned and fault code on gearbox was 4F8A ratio monitoring, gearshift 4-5..
29CD- combustion misfire cylinder 1 (I've ordered coils and plugs for this)
2DED Power management, closed circuit current violation.
This is all since fitting JB4 the gear change when in 4 to 5 with around 13psi (map1) is like it's hunting for the gear and slips.
It's a slow communication with cam time line according to the technician. Is there settings for the JB4 that can be altered to rectify this or have I a dud box..
I've had my adaptions reset on autobox as it reached it limit for learning driving modes..
Again any help would be great or get tagging to who has same experiences.
Thankyou
