ABS + Traction control warning + Error codes
03-28-2016, 08:39 PM | #1 |
Rep 85
I went over a curb when pulling out from a parking space on my rear passenger wheel and a few second later a warning light for ABS failure, traction control and handbrake warning came on.
I took it to the garage and i got the following codes coming up as well as the steering angle sensor being way off: - 5DF0 & 5DF1 He attempted to reset the steering angle but i'm pretty sure it wasn't done properly / after turning ignition off and on again was once again wrong. My battery has been on the way out for a while as well. Anyway the garage told me to have the ABS pump repaired so I sent it to ECUtesting who have said there is no fault with the unit! I have asked for the pump to be sent back and going ahead with replacing the battery and doing a wheel alignment as I believe this needs doing... Hoping that this solves the issue. Any ideas if this fails? Last edited by germanwhip; 04-18-2016 at 08:40 AM.. |
04-18-2016, 08:05 AM | #4 |
Rep 85
Battery and pump will be fitted tomorrow. If the codes are still present which I'm guessing they will be, I think my alignment is definitely off so that will be the next step I suppose..... Well this is getting expensive! Should have done this the other way round.... but the garage told me they corrected the wheel angle which was waaaay off, but i'm not sure it was done properly.
