Auto levelling sensors retrofit question
03-28-2016, 08:44 AM | #1 |
529
Rep 2,503
So, I've had my bi-xenon headlamps installed in my 2007 e90 330d for a while. FRM2 XE also installed and coded. Works really well as is, but I still have a unused connectors for for front and rear sensors which came with the BMW retrofit harness. The cheap price of sensor / parts means this should be a no brainer to do, and pretty simple as all the wiring is done.
The retrofit PDF file is for LHD drive cars however. I just want to double check that everything is reversed for RHD? I assume retrofit level sensors are both installed front and back on the DRIVERS side - in our case RH side? Anyone be able to take a quick photo for me of their sensors installed? Thanks in advance. |
03-29-2016, 01:38 PM | #4 |
28
Rep 323
I've done the full retrofit and I installed mine on the passenger side, front and rear, reason for this was there's a 'notch that the sensor butts upto on the lower arm on passenger side, but saying that I'm not sure if it is on the drivers arm too I haven't looked
03-29-2016, 01:40 PM | #5 |
175
Rep 1,596
My car has factory Xenons, and the sensors are mounted on the passenger side.
The diagram even shows this... The only difference on RHD cars is that dotted line! |
03-30-2016, 04:35 AM | #7 |
840
Rep 1,993
Drives: F30 335d
As Aragorn says the dotted line is only applicable to RHD cars.
Done the retrofit myself with levellers so I know
if I've helped - an Appreciate would be, er, very appreciated!
03-31-2016, 02:34 AM | #8 |
840
Rep 1,993
Drives: F30 335d
Sensible_ Your inbox is full, but yes, I used the proper harness, the wires go behind the dash.
05-18-2016, 04:06 AM | #9 |
529
Rep 2,503
Finally got round to putting this all in. Thanks all for your tips.
All in all I think total cost was around the £550 mark. Pretty pleased with the results. Auto levellers working great and error free. Next up, washer retrofit! |
