E90 headlamp (adaptive error light and condensation)
03-26-2016, 11:50 AM | #1 |
7
Rep 77
Hi - to begin troubleshooting, should I remove the entire light assembly/housing?
If so, what's the procedure to search on the boards to help with DIY for it Thank you in advance for the advice. |
03-30-2016, 06:47 AM | #3 |
7
Rep 77
03-30-2016, 10:15 AM | #4 |
238
Rep 947
Scan faults.
There are specific faults for when the SMCII get shorted out. Search the forum for those codes. I think one is 9CBB First fix you leak. Otherwise the module will short again. If there are no obvious cracks, it's most often a bulb door seal that has gone bad or was not installed properly. You can buy a used module off eBay for around $100-$150. If you're lucky, it will be plug and play. If not, you just need to default the module using NCS Expert with a profile that has manipulation turned off (granted you buy the correct module). Buying a module that came from the same chassis (E9x), region (LHD vs RHD), and side (driver or passenger) will increase the chances of the module being plug and play. |
