E90 335 xdrive catless dp install cost?
03-24-2016, 12:05 PM | #1 |
11’ Msport 335i E90
Rep 68
Hey guys,
So I have a 2009 335 sedan with xdrive and I'm wanting to soon purchase vrsf catless downpipes. I understand that with the xdrive, they are a bit more of a pain to install then the standard rwd. Just wondering how much it is for install, and where the best place is to take it?? Thanks guys |
03-24-2016, 01:28 PM | #2 |
BimmerPost Supporting Vendor
24273
Rep 190,975
Indy or exhaust shop should do it
Takes 3-4 hours
03-24-2016, 03:08 PM | #5 |
24273
Rep 190,975
I have seen some take 6 hours on RWD
03-24-2016, 04:00 PM | #6 |
11’ Msport 335i E90
Rep 68
Haha holy lord boys, so it varies depending on the mechanics experience it sounds like. Takes either 1.5 hours or 11 haha, why is a all wheel drive so much harder then rwd?
03-24-2016, 06:01 PM | #7 |
72
Rep 116
Book time on catalytic converter removal is 5.5 hours on an xi. That's what I would charge. This is also the reason I haven't installed my meowless pipes. No real gains for the time invested. I may do them when I do my Hexon inlets if I can't sneak the back turbo silicone inlet on all sneaky like.
03-24-2016, 06:23 PM | #8 |
77
Rep 466
There is no room at all on the AWD, so it is a bitch to work on. That is why I had my Indy do it. Keep in mind the 11 hours included the Inlets, so it would be much less for DP's only. I think he said probably 5-6 hours for the DP's only.
03-25-2016, 11:47 AM | #9 |
11’ Msport 335i E90
Rep 68
I see you got the same year car as mine. Yeah I guess so hey, idk I might not get them then. I was gonna do catless downpipes with the performance exhaust, but maybe I'll just put vibrant resonators in place of the second cats and muffler delete.
03-25-2016, 01:02 PM | #11 |
Rep 28
I installed mine on my e92 335xi by myself and I'm by no means an advanced mechanic and it took me about 3.5-4 hours all said and done. I freaked myself out a bit reading horror stories but it really isn't too bad. A mechanic should be able to do it in 3 I'd say.
03-25-2016, 01:26 PM | #12 | |
23
Rep 294
03-25-2016, 09:59 PM | #13 |
32
Rep 208
Depends on if your bolts are rusted or good shape. I cant recall if Canada uses salt on roads I had mine done in 3 hrs but shop said they have done XI that took 5-6 hrs. Either way its worth it for the sound, throttle response and also you will notice how much faster the turbos spool at any rpm.
03-25-2016, 10:34 PM | #14 |
447
Rep 1,060
I jest got a 2010 335i and still have my 09 335xi and I am taking my vrsf downpipe off the Xi if so I can sell them to you I had them for about 5k miles when I installed them I had to drop the subframe and disconnect the steering rack from the subframe and the engine mounts it was a pain but I got it in like 3-4 hours. On my 335i it only look me like 1 1/2 hours so much easier then the Xi.
