03-21-2016, 01:11 PM | #1 |
43
Rep 72
Strut braces from M2 for M235i coupe?
Anyone know if the strut tower braces from the M2 (and 228i/M235i convertibles too) fit the M235i coupe? I would assume they do. Seems like a cheap thing to bolt in.
Part numbers are 51647301929 and 51647301930. |
03-21-2016, 03:45 PM | #2 |
659
Rep 3,320
I might order these and give them a try , I don't see why it wouldn't work , or why bmw would have included these from the factory
07-12-2017, 12:35 PM | #7 | |
715
Rep 1,541
07-12-2017, 01:09 PM | #8 |
4516
Rep 8,942
Path of least resistance may be contacting KC Design and getting their strut brace. A few of us are running them and quite pleased with the product.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
07-12-2017, 03:50 PM | #9 |
1165
Rep 1,931
anything can be fabricated to work.
that being said, to get it to work, will take alot of custom modification and fabrication. Look at the m235R race car that use it. IMO, not worth the hassle.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
07-13-2017, 03:47 AM | #10 | |
1779
Rep 4,515
M235R uses M3/M4 alloy and CF braces - from photo below - It look like it doesn't use the M2/F2x convertible side pressed steel bracings...
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
07-19-2017, 11:12 AM | #11 | |
4516
Rep 8,942
2022 Macan S
10-16-2017, 02:45 PM | #12 |
4488
Rep 10,473
The brackets need to be welded on, I will be doing that in a few weeks, but it looks like an easy and inexpensive mod, you will also need the convertible or M2 front crosslink.
10-16-2017, 07:22 PM | #13 |
454
Rep 986
For the M2 style you need two sets of brackets, Strut tower and side fender. Strut tower one is definitely welded from factory, the other one there are a couple holes here, but not sure if you need to weld it.
See parts 5 and 6 attached. |
10-22-2017, 09:29 PM | #14 |
4488
Rep 10,473
Both are welded on actually if you dont want to weld them another way you can possibly attach them is using BMWs rivet bonding repair method, they use this even when replacing front frame rails or wheelhouse sections. Our f30s actually already have some front upper apron sections that are attached with this glue, its very strong and becomes rock hard, if you dont want to weld your new car you can use the bonding method but the adhesive is not cheap and you need special BMW rivets (although maybe you can get away with regular steel rivets as well as its just a reinforcement plate)
01-15-2019, 08:04 AM | #15 |
23
Rep 64
Anyone have any luck welding these on?
