03-19-2016, 04:48 AM | #1 |
254
Rep 922
Quick help with wheels needed!
Trying to swap my winter wheels but I can't get the first one off!? Bolts out but it's stuck fast. Am i missing something?
Help would be appreciated! It's on the Jack now. |
03-19-2016, 05:01 AM | #4 |
2119
Rep 3,066
The alloy will have corroded around the hub.
Best to use a rubber mallet if you have one and a block so as not to damage the wheel and rotate it as you go. Although try not hitting the wheel at first maybe just a gentle tap to the tyre wall will shift it. You notice that it will gradually start to come off patience is the thing. Don't try to bash it off it one go as you can damage the wheel. Wire brush all around the hub & put copper ease on after & make sure that the inside of your summer wheels are not corroded where the hub sits & they'll be fine. Some people have said that they get rust coming through the centre caps. So if you have the time when the wheels are off, remove the plastic hub caps and clean out all the rust in there (it's only a hollow in the casting) then copper ease it or similar& put the caps back on. Preventative maintenance! |
03-19-2016, 06:46 AM | #9 |
254
Rep 922
03-19-2016, 07:09 AM | #10 |
2119
Rep 3,066
03-19-2016, 07:31 AM | #11 |
167
Rep 795
