Hot air always blowing on feet?
03-17-2016, 02:34 PM | #1 |
69
Rep 718
It seems like in my 335i I always have hot air blowing on my feet.
Yesterday it was 77 degrees out, I had the hvac set to 67 with the AC turned off. Cool air was blowing from the face vents, but down at my foot it was blowing hot air. Does anyone else get this? Any idea why it does this? The auto climate control in general in this car seems not to work great. My e46 I used to just set it at 68 and forget it. I feel like in this car I'm always adjusting it.
03-17-2016, 03:15 PM | #2 |
324
Rep 2,014
Did you twist the dial between the center vents to blue?
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
03-17-2016, 03:18 PM | #3 |
69
Rep 718
Yes, that controls the upper vents. I have that all the way to blue and it blows cold air out of the upper vents, but hot comes out of the foot vents.
I'm wondering if it could be heat from the engine that causes the air by the feet to be hot all the time. The engine does seem to put of quite a bit of heat
03-17-2016, 03:36 PM | #4 | |
681
Rep 3,696
03-17-2016, 03:44 PM | #5 |
682
Rep 1,155
fazman that is 100% incorrect. the red/blue dial is to adjust the vents blowing in your face by a few degrees. that way the car can cool/heat quickly without getting the cold/hot air blown in your face.
03-18-2016, 05:55 AM | #6 |
17365
Rep 18,762
OP, it could be a stuck module. Have you tried going to manual mode and selecting just the dash and windshield airflow positins to see if the air at the feet shuts off?
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
03-18-2016, 06:48 AM | #7 |
74
Rep 295
I had a similar thing occur to me as well. It was always hot around the leg area even when i had AC turned off. Even my keyfob was hot at times. Oddly it went away when i did a engine oil change. Are any codes coming up?
03-18-2016, 07:10 AM | #8 |
2341
Rep 3,542
Your issue is the heater core valves located in the engine compartment.
Had exact same issue on my E39 and one valve was stuck open. Looking at around $200-300 Canadian for that part. Last edited by Wolf 335; 03-18-2016 at 07:20 AM.. |
03-18-2016, 07:50 AM | #9 | |
69
Rep 718
It almost seems like the temp is just calibrated wrong or something. When it is almost 80 out I shouldn't need to turn the temp down to low 60s just to stop hot air from blowing out the foot vents.
03-18-2016, 07:52 AM | #10 |
69
Rep 718
Any advice on further steps to diagnose this?
03-18-2016, 08:50 AM | #11 |
2341
Rep 3,542
My diagnosis was from a private bmw shop. It was a while back and I can't recall how mechanic diagnosed it.
I do remember him saying that I was lucky it was stuck this way, because in some cases (depending on the valve position) you don't get any heat which can be an issue in the winter. Does the heat blowing at your feet stop once you turn on A/C? Have you had you car scanned for any faults? |
03-18-2016, 09:00 AM | #12 | |
69
Rep 718
When I tried to do some more searching I saw a lot of people have the cold air only issue.
03-18-2016, 09:16 AM | #13 |
17365
Rep 18,762
03-18-2016, 10:17 AM | #14 | |
164
Rep 598
Try it. When it's 100 degrees put the little vent dial all the way to hot and set the HVAC controls to 60. I guarantee the car will cool off. If the vent dial was the sole control of air temperature, you would have full blast heat. Also note that you can operate the HVAC in manual mode. If you take it off auto, the temp dials will change the temperature of the air (instead of the target cabin temp) only. The little dial by the vent is for minor adjustments for just those vents in case you want heat in the car but cool air on your face. My old 80s Honda had it too (but it mechanical not electronic). The logic behind automatic HVAC is actually rather complex. |
03-18-2016, 10:22 AM | #15 | |
164
Rep 598
With the A/C off, the air temp can only get so low, and the engine will warm it up a bit. Try putting it on recirculate and see if that makes a difference. And maybe it's that way by design. I'm just brainstorming here, but a good way to dehumidify air is to first heat it and then cool it. If you manually turn the A/C off you don't get the cooling. |
03-18-2016, 11:06 AM | #16 | |
681
Rep 3,696
03-18-2016, 12:57 PM | #17 |
38
Rep 254
unless you have a "face & bypass" setup (which some cars might have) you are usually better off cooling the air first, then reheating to get the cooling coil as cold as possible to remove the most moisture from the air.
This is how all commercial HVAC systems are configured. You cool the air to a target setpoint to manage airflow and reheat to maintain room temperature. If the room needs maximum cooling, you provide no reheat and max. airflow. To save energy, you can recover heat from the condenser on the central cooling plant. |
04-22-2016, 08:10 AM | #18 |
69
Rep 718
I was playing around with my temp settings and found I can make the feet vents blow cool air, I just have to turn the temp down way further than I should need to to get them.
It was 70+ degrees outside and the car was fairly warm. I set the foot vents to always be on, AC off. Driving around with the temp set at about 67 there was warm air blowing on my feet. I turned the temp down to 60 and cool air finally started to blow out. It seems like the temp may be calibrated wrong or something. Does anyone know of a way to reset this in INPA or some other way?
04-13-2023, 09:47 PM | #19 | |
Rep 14
04-14-2023, 11:16 AM | #20 | |
2717
Rep 4,050
1) Do Forum Search: "exact same issue". 2) When that doesn't get any reliable information: a) get Fault Codes read in IHKA & JBE Modules & report them HERE. b) If you don't have a Scan Tool or Diagnostic Software (INPA/ISTA) that can read fault codes in those modules, try Advance Auto, AutoZone, etc. for free code reading. c) When you report Fault Codes here, please indicate exactly WHAT does NOT work as it should, the settings selected on Climate Control Panel, and what happens a minute after selecting MAX on the Driver side T-Stat (which SHOULD over-ride Control Panel settings). George |
04-14-2023, 11:35 AM | #21 | |
Rep 14
thanks for your input.
I have ISTA P and ICOM. Have the lastest firmware update installed in all modules. Test shows no errors. This is a very specific issue, as the previous message I quoted. I did search the forum. I know culprits could be water valve or the seal from the steering column at the firewall causes similar complaints. However in my case the footwell fan does blow cold air when I drop the temp below 65F and I was wondering if the user I quoted who had the same issue found the culprit which would help me direct my attention to. Quote:
Update: just tested again and everything seems to work fine footwell blowing footwell blowing cold air even at higher temperature settings as long as the cabin temperature needs to drop. Either was a normal IHKA behavior or was an intermittent issue seems to have resolved. Last edited by clubs07; 04-14-2023 at 11:54 AM.. |
