Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N55 Turbo Engine Tuning and Exhaust Modifications - 335i Tuning > Engine fault! Reduced power (2C01 and 2BF8)
      03-16-2016, 03:43 PM   #1
alexnran
Drives: E92 335i <2011> E70 4.0d
Hey, guys!
Lately I'm having a repeating error message: "Engine fault! Reduced power. Full engine power no longer available. Possible to continue journey. Drive moderately. Have the problem checked by the nearest BMW service."
I ran a check and the following codes came up:
002C01 - High pressure fuel, plausibility Pressure too low
002BF8 - Rail pressure sensor, signal: Permanently stuck
and
00A8F9 - CBX-MEDIA: Software reset (I guess this one is because of a software reset I asked for, in order to have the latest updates and solve a lag problem I had while driving away in D mode).
I'm sure that, unfortunately, I'm not the only one having these errors.
How did you fix the problem, was it only the HPFP or another part also?
Thanks!
      03-17-2016, 08:54 AM   #2
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
I have seen several people posting about the first code recently. I know one person was replacing the sensor. Do some searching on that code in here and N54tech and you should be able to get some more info. I don't remember him posting more after doing the sensor so that may have fixed his problem.
      03-29-2016, 09:54 PM   #3
EB89
EB89's Avatar
Australia
541
Drives: 2011 335i e92 DCT
Do you have a JB4 by chance?
/ MHD Stage 2+ / AR CATLESS DP / PE MOD 4 INCH TIPS / BMR FMIC / K&N DROP IN / BMS CP /
      11-05-2018, 09:51 AM   #4
mmachinya
Drives: BMW E90 N55B30A
Hello
I can see this is an old post, but how did you resolve the 2 codes being 2C01 and 2BF8 ?
      11-05-2018, 10:57 AM   #5
SnapCoupe
BMW Portland
Drives: Z4M Coupe/E90 335i
Originally Posted by mmachinya View Post
Hello
If the car isn't going into limp mode, try clearing the codes and see if the rail pressure sensor code comes back on. If it does, I would proceed with replacing the rail pressure sensor ($50-$60 on FCPEuro).
If your car is going in and out of limp mode, your HPFP is probably going out. When my car was doing this a month or two ago, I was also getting the rail pressure sensor code, but once I replaced the HPFP I never saw it again. Sometimes when the pump goes out the sensor will send a "false fault".
2011 335i N55/6MT/M-Sport
MHD Stage 2+, VRSF Downpipe, VRSF 7" FMIC, BMS Intake, BMS Chargepipe, Performance Exhaust Mod, F10 550i Clutch, BMS CDV, BMW Performance SSK, M3 Control Arms, ST Coilovers, Apex ARC-8 wheels, Michelin PS4S
