03-15-2016, 02:35 PM | #1 |
3105
Rep 7,032
Drives: 335xd Msport +
Servicing modifications and warranty woes ???
Got my service indicator showing my cars due for a service in 2500 miles so I'll get it done in about 1-2 months time to try and max out the service plan
So my issues are . I've got a couple of suspension mods and don't know what to do my thoughts are Strut brace - approx 10 mins to take off so it's coming off prior to the service and then straight back on Wheel spacers just bought a set and an keen to experience their testosterone enhancing benefits so do I stick them on this weekend when I hopefully put the summers back on and take them off again prior to the service Do I leave them off until after the service Do I put them on and leave them on for the service and hope I don't get any issues and allow BMW wriggle room to get out of any issues - I believe adaptive dampers don't come cheap. Any thoughts comments experiences welcomed
03-15-2016, 02:42 PM | #2 |
409
Rep 903
Pita I know but I would remove everything you can. I would think they would find any excuse to get out of any warranty claim.
"Wheel spacers fitted sir, That's definitely why you have corrosion on your bonnet. Sorry but we can't cover this under warranty any more" Just my cynical side |
03-15-2016, 03:51 PM | #3 |
6416
Rep 8,498
What undue effect will a strut brace and wheel spacers have had on the car, especially the mechanicals ? Unless your wheel bearings are shot, none.
In my experience leave them in place and build a good relationship with the service manager - you may find he's interested in your mods. I have no choice but to leave my mods as-is, and the dealer hadn't batted an eyelid. The BMW warranty has covered everything that's required rectification/replacement (quite a bit) because the dealership and I know that the work that I've had done hasn't effected the faults that have been found. Sounds like your car is going in for a routine service - don't worry about it.
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
03-15-2016, 03:58 PM | #4 |
8566
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
Leave them as they are. I've had my car serviced 4 times at 2 different dealers with all the mods you have and more and not had any problems at all.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
03-15-2016, 04:08 PM | #5 |
3105
Rep 7,032
Yes just a routine first service.
Know the ACS springs won't be an issue as ACS make up the shortfall. The man in me says stick it all on and to hell with them The fretter says it's an hour and half job and you sneak under the radar.
03-15-2016, 04:31 PM | #6 |
46
Rep 327
I had a Chassis error keep coming up on the display (car has a remap and MPSS tyres and ACS springs )turned out to be a wiring loom fault which could have been due to fitting the ACSsprings (non franchised dealer maybe not as proficient as needed) all replaced under warranty and they even honoured my lacquer peel claim for a new alloy wheel (peel was the size of a 5p)...it does help to use the same dealer that the car was purchased from
03-15-2016, 04:33 PM | #7 | |
8566
Rep 19,982
03-15-2016, 04:40 PM | #8 |
3105
Rep 7,032
Worried about there being an issue now or in the future with one of the suspension components say for arguments sake an adaptive damper which I believe are quite expensive.
Presume the dealers will put a marker/ record the fact that the car had some sort of suspension mod and then could use that as an excuse to void the warranty. Thinks it's more about peace of mind really as if the dealers don't know there are any mods can't then use that as a reason to void.
03-15-2016, 04:45 PM | #9 | |
8566
Rep 19,982
MarkG335 has had a damper replaced under warranty with ACS springs on. And ACS will cover you even in the tiny chance a spring was to blame. The strut brace does absolutely nothing so it couldn't be implicated in anything. So give you don't have anything wrong with your car in the first place I think you're over worrying about nothing.
03-16-2016, 05:25 PM | #10 | |
3105
Rep 7,032
On the other hand for approx 1 hr of my labour it's a peace of mind thing.
03-16-2016, 05:31 PM | #11 |
8566
Rep 19,982
Indeed. It's your car, your time, your peace of mind.... Your decision
03-16-2016, 05:34 PM | #12 | |
3105
Rep 7,032
Just an old lady deep down !!! Thanks for the input though. Appreciated.
