03-15-2016, 02:30 AM | #1 |
773
Rep 1,643
Drives: 2020 Audi SQ7 & 2019 AM DB11
Location: The Democratic Peoples Republic Of South East England
First DPF Re-Gen
Car did first DPF regen on the way to work this morning @ 180mls.
What a bloody stink! Had to turn the ventaliation off. |
03-15-2016, 02:42 AM | #2 |
2811
Rep 4,935
Drives: 340i MPPSK
Is that the 'bad eggs' smell you sometimes get a whiff of when out and about?
Life is a state of mind |
03-15-2016, 03:06 AM | #3 | |
10995
Rep 32,881
03-15-2016, 03:25 AM | #4 | |
652
Rep 3,445
Drives: G22 M440D
'bad eggs' is more likely the output from petrol catalytic converters - nothing like a DPF regen. D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
03-15-2016, 05:31 AM | #7 |
90
Rep 274
Do the BM's operate like the VAG cars that run the fan for ten minutes if you stop the car during a regen? Its a right PITA sometimes when you get someone running after you telling you you've left the car turned on!
F31 335d M Sport | Estoril Blue & CR | M Sport+ | Pro Nav | Comfort Pack | Adaptive M Sport suspension | Active Cruise
03-15-2016, 05:43 AM | #9 |
6659
Rep 15,858
Type of driving may mean they are mostly passive regenerations, or you just don't notice any active regenerations. They'll be happening, as you'd be having DPF issues by now, if they were not.
Regeneration intervals in typical driving are every 300 - 600 miles. EU6 compliant engines have an even more complex regeneration activity. |
03-15-2016, 05:55 AM | #10 |
234
Rep 738
I wish the regen could be initiated, or at least indicated that it's happening.
My mileage is split between some long runs and then a short spell of very short runs. If I new a regen was happening, I could keep driving until it had finished. Or start it if I knew I was on a longer run
X3 M40i Carbon Black
03-15-2016, 06:13 AM | #11 | |
6659
Rep 15,858
03-15-2016, 06:59 AM | #12 | |
652
Rep 3,445
Drives: G22 M440D
D:
03-15-2016, 07:43 AM | #13 |
243
Rep 710
I can hear when mine is doing its thing as the exhaust note changes. They annoying thing is I'll do a few hounded miles then get 2miles from home and hear it start. I just end up driving around for a bit.
03-15-2016, 08:50 AM | #14 |
6733
Rep 20,651
I was talking to BMW tech and he said dpf regen is disabled when driving in ECO mode.
Have not really checked if this is or is not the case. However it does sound logical. It might be worth those that regularly use it, asking the question. |
03-15-2016, 09:44 AM | #15 |
234
Rep 738
If you did use Eco pro all the time, surely it wouldn't allow the filter to clog up??
03-15-2016, 10:28 AM | #16 | |
6733
Rep 20,651
A lot depends on what parameters have been set for triggering a regen. I know on Ford to force one, it was over 2k revs, 50mph minimum and about 25 miles after the engine had come to temp. |
03-15-2016, 12:50 PM | #18 |
773
Rep 1,643
Think all DPF are designed to clog up whatever the driving mode.
The byproduct of the fuel compression which gets trapped in the DPF willl remain the same in any mode. Effectivatly the car has to raise the engine temp to enable a flush/regen of the DPF. I suppose its like wringing out a sponge full of water so you can dip it again in the water to absorb more water. |
03-15-2016, 03:55 PM | #19 | |
6414
Rep 8,498
Current : F31 330sD, remapped, Ohlins Road & Track, Millway camber plates, Quaife LSD, Stoptech brakes + Pagid RSL1 pads all round, Weichers front strut brace, Eibach front & rear anti-roll bars, Michelin MP4S.
