03-15-2016, 02:13 AM | #1 |
1076
Rep 2,355
Brake shudder - warped discs are a myth!
Hi
Has anyone succesfully removed brake shudder by sanding their brake discs? The reason I ask is, that according to Brembo, there is no such thing as warped discs! However, brake pad material can be transferred unevenly which will give the same result. Edit: It is Stoptech that claims the above http://www.stoptech.com/technical-su...d-other-myths#
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) Last edited by harkes; 03-15-2016 at 03:05 AM.. |
03-15-2016, 02:55 AM | #2 | |
409
Rep 903
Sanding? do you mean skimming/machining a few thou off? |
03-15-2016, 03:03 AM | #3 | |
1076
Rep 2,355
http://www.clublexus.com/forums/ls-4...e-problem.html Google: garnet paper brake rotor Ill give this a try in the weekend
(A Dane in China) Last edited by harkes; 03-15-2016 at 03:12 AM.. |
03-15-2016, 08:06 AM | #4 |
1607
Rep 3,943
Do you track your car extensively?
03-15-2016, 08:33 AM | #5 |
409
Rep 903
04-04-2016, 10:18 PM | #6 |
432
Rep 937
They are correct it's always uneven pad deposits. As soon as you feel it you need to bed them in. If not you can always get it out but you might have to use a more aggressive pad.
My dad ended up getting 100k+ on his original brakes by doing this...granted he drives normal.
F80 M3-DCT MaxPSI CH, BM3 with F80 Paul E85 and Custom Rom track tune MCS 2Way Remotes
Signature SV104 E46 M3 F85 X5M https://www.instagram.com/fastmacm3/ |
