What is the Best suspension upgrade ( comfort)
03-10-2016, 05:36 AM | #1 |
128
Rep 1,362
I am in the process of possibly ask JR to tune my car and buying the best coilover set up.
What would you recommend so the car is not too low and provide a " Lexus LS " feel ? Ohlins R&T ? |
03-10-2016, 09:38 AM | #2 |
54
Rep 215
Drives: E39 M5, F15 35d
Any suspension that lowers the car will be firmer than stock, since a decreased ride height necessitates a firmer rate in order to prevent suspension crash or bottoming. That being said, there is absolutely no way to make your 335D feel like a "Lexus LS". The LS is tuned purely for comfort and rides on long-travel springs and shocks with low rates, big squishy rubber bushings, and tall-sidewall tires. Driving an LS is kind of like piloting a yacht; you're slightly aware that something is going on under you, but it's barely perceptible.
03-10-2016, 10:40 AM | #3 | |
Jumping Jack Flash
321
Rep 1,692
Drives: 2021 X3 M40i
2021 X3 M40i: M Sport Differential, Adaptive M Suspension.
Previous BMWs: 1971 BMW 2002, 1973 BMW R75/5, and 2011 BMW 335d Previous Other Vehicles: '67 Cougar, '70 911e, '86 Jetta Diesel, '05 and '12 Foresters, et al. |
03-10-2016, 06:33 PM | #5 |
143
Rep 634
I'm going with a simple upgrade to Bilsteins B6 model (heavy duty, not sport) which has the better monotube design. I'm hoping for a more controlled ride without being too stiff. I felt the factory shocks were all wrong for the car from the beginning, especially from the rear which always had an extra bounce over bumps. At the same time going to put on Bridgestone driveguard runflats which ride nearly the same as a conventional tire (or so everyone seems to say). I'm tired of bending rims over our crappy roads and hope this combo will help.
I've used Koni FSDs on 2 other cars and was dissapointed. On our 540 the fronts shocks were completely shot in 12K miles, felt like the car would bounce off the road. On our E46 they did not wear out, but all of them rust very badly and am worried about the spring perch breaking off some day. |
03-10-2016, 08:07 PM | #6 | |
671
Rep 1,442
03-10-2016, 10:19 PM | #7 | |
23
Rep 133
Sorry man that supple, isolated, an acoustically muffled lexus feel is just not going to happen. Last weekend I've driven the 2016 Lexus NXt? (small 4wd SUV) and it's capacity to handle bumps is LIGHT YEARS ahead of my 335d with Ohlins. It really rides like a dream. I think a big component that provides this nice driving experience is effective sound deadening and taller tire sidewall. That being said, I like the Ohlins and they're more comfortable than stock suspension- no doubt. (But stock setup is crap) If you're planning to keep car for several years there's really no choice but to upgrade shocks/springs. That being said- you'll never achieve that lexus ride. |
03-10-2016, 11:03 PM | #8 |
44
Rep 241
The Ohlins sound great but hard to justify $2k+ for shocks. Especially when that $2k could buy a set of hybrid turbos instead!
03-11-2016, 11:19 AM | #9 |
143
Rep 634
Maybe, but not at over $2000. This is nearly 4x what the Bilsteins will cost. Just wanted a small improvement over stock, no need to change springs and such. The OEM shocks are not worn out, they were just wrong for the car to begin with. I'm not looking for a Lexus (aka Camry) ride, just a little more control and less damaging to the rims.
I'll know in less than a week how the Bilsteins work out. |
03-11-2016, 11:27 AM | #10 |
229
Rep 3,489
Drives: Montego Blue 335d
yes my FSDs went out also but the ride is superb to OEM non sport that i have, don't want to lower it cause the roads and specifically in Dominican Republic they have what is called Policias Muertos o better said road hump to lower your speed specifically around schools and some Barrios
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
03-12-2016, 01:04 PM | #12 | |
158
Rep 866
03-12-2016, 05:05 PM | #13 |
36
Rep 103
Any reason you're wanting to use coilovers ?
The Alpina B3 Bi Turbo springs and dampers would be good, either that or the Birds B3 Sport suspension kit (Bilstein based, bespoke damper rates and springs) : http://www.birdsauto.com/parts/L9031928335 http://www.birdsauto.com/product-inf...330i-335d-330d |
03-14-2016, 08:19 AM | #14 |
229
Rep 3,489
Pierre I'll stick to FSDs since they hv a lifetime warranty, the roads in Dominican Republic are way better than Puerto Rico's roads.
03-14-2016, 11:04 AM | #16 |
103
Rep 580
My stock factory BMW suspension still feels fine at 102k miles. Maybe I'm just not that perceptive, or the relatively good roads around here offset any shortcomings or wear. In any case, I expect to make this decision myself sooner or later, so listening carefully...
03-14-2016, 12:19 PM | #17 |
143
Rep 634
My 2 issues with the suspension are the ease to which wheels are bent, and not enough dampening, especially in the rear. They made the shocks too soft (in my opinion) to compensate for the hard riding runflats. The rear always has had extra bounce or two after a bump. If I wanted a ride like a Fleetwood, I would have bought one. Again this is by BMW design, the shocks have not failed.
03-14-2016, 01:27 PM | #18 | |
95
Rep 308
Drives: 2011 335d M-Sport, Nav/Blinds
I'm torn between the Bilstein B12 Pro Kit and just a straight Koni FSD install. Still undecided. |
03-16-2016, 10:18 AM | #19 |
103
Rep 580
03-16-2016, 10:28 AM | #21 | |
2032
Rep 8,339
