03-08-2016, 02:29 PM | #1 |
BimmerPost Supporting Vendor
3308
Rep 22,755
getBMWparts.com | Dinan Performance Springs for F30 340i (RWD) + FREE Shipping!!!
getBMWparts.com | Dinan Performance Springs for F30 340i (RWD) + FREE Shipping!!! Dinan Performance Springs for F30 340i (RWD)!!! Product Description: Special Note: Not for xDrive models. Suspension systems that not only transform the stance of the vehicle but also maintain ride quality and improve upon handling are what Dinan® suspensions are known for. This is accomplished by pairing springs sets with bump stops, spring perches or both to maintain suspension travel resulting in a smooth ride while also improving mechanical grip and handling. This is what makes Dinan suspension systems unique. While we are able to sell each component separately it is highly recommend that both the spring sets and the supplemental ride quality and handling kits are used in tandem in order to maintain the Dinan quality standards our customers are used to. Experience the Dinan difference with this combination and enjoy the ride it provides. Dinan's Performance Spring set for the F30 340i (non xDrive) provides greater control over body roll by virtue of carefully calibrated spring rates. Additionally, Dinan® lowers the 340i by a full 1" in front and 1" in the rear for improved suspension geometry and an even more aggressive stance. The Dinan springs are CNC wound with high tensile chrome silicon wire and shot peened for stress relief to last the life of the car. The 25% increase in stiffness in front and 34% increase in the rear will reduce the rear suspension compression under acceleration and front suspension compression (or dive) under braking, giving your car a more controlled feel. The Dinan performance springs will also provide a noticeable improvement in grip, for high speed driving situations that will inspire confidence in your car's capabilities. The reduced body roll makes the steering more responsive to driver input and will be noticed at speeds as low as 20 mph, up to the top speed of the vehicle. Benefits of the Dinan® Performance Spring Set for the F30 340i (non xDrive):
PM or Email for Pricing + FREE US Ground Shipping!!! Last edited by Evan@Tischer; 03-15-2021 at 03:40 PM.. |
Tags |
dinan, dinan springs, getbmwparts, springs, tischer |
