Vibration
03-07-2016, 03:53 PM | #1 |
18
Rep 65
Vibration
Has anyone else experienced a vibration through the steering wheels and under the seat when they first start their D up after it's been sitting overnight or for a few hours ? I notice the vibration when I put the car in drive and my foot is on the brake at a red light. Also feel a vibration through the steering wheel when I go over a speed bump. Any one else experience this ?
03-08-2016, 08:19 PM | #5 |
Rep 14
I get this from time to time as well. My car only has 47k though. If I rev it a little bit it goes away. In the winter, the engine idles a little lower in rpm for me vs summer. 650 rpm winter vs 750 rpm summer. That small change seems to make it go away. It doesn't bother me though as it is very slight, but noticeable.
03-08-2016, 09:12 PM | #6 |
88
Rep 358
I've burned through a few bad injectors and would get a bit of a rough idle now and then like you're describing. It always threw a code after a few occurrences.
As for the speed bumps, it's safe to assume you've got a worn component or three given your mileage. |
03-08-2016, 09:44 PM | #7 |
Oil Burner
21
Rep 119
Drives: 2009 335d Barbera Red Metallic
I just discovered the vacuum controlled engine mounts. Mine was cracked, although no symptoms. Definitely check your engine mounts. See my post in my plan and tools about this, with photo
2009 335d Barbera Red Metallic; Mods: BPC tuned, Bohl Diesel Performance, Laser Veil, BelTronics Pro 500
03-20-2016, 02:35 PM | #8 |
18
Rep 65
03-20-2016, 03:28 PM | #9 | |
63
Rep 296
Drives: E90 335d | i3 REx
I had similar issues.
2011 E90 335d M Sport | KW V3 | M3 Bits (arms/bushings/sways) | JBD | Apex ARC-8 w/PSS
2015 i3 REx | Solar Orange | Tera World | Tech |
03-21-2016, 06:55 AM | #10 |
13
Rep 128
+1 motor mounts. I had rough idle almost exclusively in park, got motor mounts replaced and it's perfect. I was told that it is common on our cars.
03-21-2016, 11:16 AM | #11 | |
198
Rep 844
I'll check the mounts. Does anyone have part numbers handy? |
03-21-2016, 11:46 AM | #12 |
870
Rep 2,615
Before you go change the mounts, please check your vacuum lines. The driver's side gets easily pinched between the subframe and front suspension brace.
03-22-2016, 07:43 AM | #13 |
143
Rep 634
I think a little extra vibration when cold is to be expected of a diesel. Mine has done it since new.
03-22-2016, 09:51 AM | #14 |
18
Rep 65
a little I would understand, but not when the shake is how my shake is. Just clipped my boost hose back down. Next is to see if any vaccuum lines are loose like Yozh suggested.
03-23-2016, 12:03 AM | #15 |
870
Rep 2,615
To be honest at our cars' age I would suggest replacing those vacuum lines with some quality silicone ones. You will not be able to do them all without disassembling a lot of things, but can do a large chunk of them fairly easy. Just watch not to break some little plastic nipples that lines are connected to.
03-23-2016, 01:58 PM | #17 |
870
Rep 2,615
They are the same 3.5mm ID I believe. Brake Booster ones are different, but they are plastic and are not usually replaced. The ones under the intake manifold at the vacuum distribution block are difficult and should be done when intake is off. Make sure to be careful with plastic nipples. They are brittle. Also, watch for the thickness of the silicone hoses, some thick ones are hard to route. Ultimately, I would rather do the lines in Viton instead of silicone.
03-23-2016, 02:21 PM | #18 |
870
Rep 2,615
This may be the best candidate:
http://www.mcmaster.com/#catalog/122/131/=11o125d The one that is: $4.56 per ft. Product code: 9627T14 Fuel Resistant Blue Fluorosilicone Tubing. |
03-23-2016, 03:23 PM | #19 |
765
Rep 3,557
Thank you Yozh. Rep points for you too.
Per the other swirl flap => to blanking plates thread, I will have vacuum hose on hand when intake is pulled. Mcmaster is wonderful source of all sorts of weird parts. This is where I got parts to mount spare tire underneath trunk. The only thing would be doing different colors for identification purposes. No, I'm not pimping it out with red lipstick like somebody compared PR's scoops to. jajajaja |
