BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
  TireRack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      03-03-2008, 06:49 PM   #1
Jinxter
Jinxter's Avatar
44
Drives: 2008 BMW e92 M3
What are e92 M3 stock offset?
What is the offset of the e92 M3 19 inch rims? I tried searching for it but couldn't find it.
What is recomended for 8.5/inch fronts
and 10/inch in the rear?
the HRE rims I have below are 19"
Front 8.5, 31 offset
Rear 10, 28 offset
Anyone know how these will look or how off they are from stock (aside the wheel width)?
I know crappy iphone picture but at least its a picture.
08' e92 M3 6MT // Rogue SSK // B&B Tri Flow Exhaust // AA air filter // Mod Carbon Skirt extensions // Amuse Front/Rear Bumper // Amuse Trunk // Gloss Black Grills w/ M colors // gloss black side vents // M5 Stick with IND custom stitched boot // Carbon Firber wrap steering wheel trim // Avant Garde M364 20' (street) // Advan RS 18's (track)
      03-03-2008, 06:52 PM   #2
rzm3
Moderator
rzm3's Avatar
673
Drives: E92 M3
look for the sticky on top of the forum. also there is a calculator in e90post tire forum that you can use to compute differences.
      03-03-2008, 07:15 PM   #3
Jinxter
Jinxter's Avatar
44
thanks for the info.
Now that I have computed the difference is this a big difference?
the fronts will fit almost perfict but the rear will be
11mm LESS clearance on the strut side, and the outside edge of the wheel will EXTEND an extra 1mm
how significant is this? will the 11mm less clearence rub on the shocks or strut tower? or should I still be fine??
m3post
