02-28-2016, 07:30 PM | #1 |
BimmerPost Supporting Vendor
1505
Rep 676
Drives: '17 F31 340xi US Spec
Mission Performance: F30/F31 N47 328D Performance Reflash Dyno results
Recently we had a chance to spend entire day on a dyno, perfecting our Stage 2 re-flash for the F30/F31 328D and F25 X3 28D.
Our initial stage 1 re-flash had conservative gains of 38ft-lb and 23HP with over 48ft-lb gains at 3,000 RPMs. This re-flash made the car come alive as a daily driver and under the curve torque gains gave the car a much wider powerband. The stage 1 was built with conservative numbers in mind as it is designed for a daily driver that wants a good amount of torque, while still preserving the life of the DPF and turbo. Our latest development was a stage 2 re-flash that included DPF, EGR and SCR delete for our test vehicle. The stage 2 re-reflash gave a substantial gains of peak 100ft-lb / 44hp with a much wider powerband compared to stock. Stage 1 re-flash with original hardware Stage 2 re-flash with performance hardware package Last edited by MissionPerformance; 03-23-2016 at 02:58 PM.. |
02-29-2016, 08:55 AM | #2 |
IG @bmwF9xG80
3810
Rep 7,594
Amazing stage 2 numbers!
What does the performance hardware pkg included there?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
02-29-2016, 09:43 AM | #3 |
1505
Rep 676
Performance hardware pkg includes a stage 2 software with removed scr, egr and dpf functionality as well as a downpipe that removes original dpf. Stage2 software removes error codes assocuated with these 3 components and sets readiness monitors to ready to allow full functionality with testing equipment such as ISTA.
This package is designed to be used on an off-road/dyno testing environment. |
