02-28-2016, 04:47 PM | #1 |
1324
Rep 2,924
M2 MPE Valve Controller Question
Do you think it will be possible to configure the M2 MPE valve controller like the link below on the M3/M4 MPE using the garage opener buttons?
http://f80.bimmerpost.com/forums/sho....php?t=1229519 |
02-28-2016, 05:36 PM | #2 | |
146
Rep 173
02-28-2016, 06:13 PM | #3 | |
1324
Rep 2,924
02-28-2016, 06:42 PM | #4 |
1324
Rep 2,924
Very quick reply from CG Precision:
Yes, our controller will absolutely work on the new M2, both with the stock and M-Performance exhaust. Good job CG Precision |
02-28-2016, 07:41 PM | #5 |
1236
Rep 1,963
Nice!
Current
AW BMW M2 Past VO BMW 1M |
04-12-2016, 10:27 PM | #7 | |
94
Rep 425
04-13-2017, 09:19 PM | #8 | |
Rep 67
Drives: 2007 Z4M Coupe
Does the valve stay open when the car is turned off, so when I start it up again, it's at open position? Oh, and does it come with instruction on how to program the Homelink buttons on the rearview mirror? Thanks! Last edited by fryh1n; 04-13-2017 at 09:25 PM.. |
02-19-2018, 09:37 PM | #9 |
3179
Rep 2,577
Revive this thread anyone has used CG precision valve controller? It’s a little confusing what CG people said above, because M2 on MPE is a dual valve system.
02-20-2018, 04:44 AM | #10 |
94
Rep 158
I have it but I honestly don't think it's ever worked. I originally had it set to stock/default and open/turned on. that didn't seem to do anything. then the shop said that it was because I should have put on the open/default and closed/button pressed. So we changed it to that unit. I honestly can't tell the difference. I still have it on but I'm not sure it's done anything. probably a waste of money. I have a 2018 MT with stock exhaust.
