02-25-2016, 09:21 PM | #1 |
94
Rep 356
M235i best economical suspension upgrade?
Purchasing a 6MT M235i soon, got wholesale due to the time of year on a 2015 with 8k miles.
Looking to upgrade the suspension. I would like a drop of around 1" over stock, nothing too aggressive. Trying to keep it under $2k. Options I have considered: Bilstein HD mated with Eibach Pro springs; PSS or PSS10 coilovers; KW Street comfort or V1. Coming from an E92 M3, so I don't want to give up too much performance. Love the M3's suspension, but this is a better overall car for me; more torque around town, a bit lighter, better MPG. I won't be tracking the car aside from perhaps 1 or 2 days a year; I place zero priority on tracking the car. Thoughts? Any other easy and cheap handling upgrades while I am at it, such as sway bars? |
02-26-2016, 11:24 AM | #2 | |
1753
Rep 2,942
I'd focus on springs and Dinan Shockware software.
--Life is a journey made more exciting with a fast car.--
--Helmets are for closers.-- <<Current: "Blackened" '18 NBM Porsche 718 Cayman ... Gone (but not forgotten): "Blackened" MG '15 228i M Sport w/aFe filter/scoop, Hertz drivers, P3Cars multigauge, other goodies>> |
02-28-2016, 03:49 PM | #3 | |
284
Rep 566
You probably don't want KW street comfort or V1 because they're way too soft and you can't change anything about it. V2 is an expensive compromise because you can only tweak rebound on an otherwise soft spring and shock. The car is already too floaty. You probably don't want to make it any more "comfortable". A stiffer rear sway without an LSD may or may not be worth it. It's been reported that traction issues may arise. LSD is way over your proposed budget. One of the easiest and low-cost improvement you can make to your adaptive suspension is get Eibach Pro-Kit springs, cut the OEM bumpstops and keep the OEM shocks. Looks nice, sits a bit higher than H&R (which is probably a good thing as you still get enough of shock travel), rides nice, too. Moderately stiffer than stock but not crashy, handles better, way better at high speed, a nice improvement within the constraints of adaptive suspension. That's what I settled for after making a few blunders with adaptive suspension. Or, research the subject of KW coilovers if you're willing to go further than that. Last edited by x233; 02-28-2016 at 04:21 PM.. |
dukeapenguin41.50 |
03-07-2016, 04:18 PM | #4 |
39
Rep 127
If a modest improvement in handling and <1/2" front drop will do it for you, then M4 LCAs ($360) will give this plus adds 1 degree of camber and increases caster. Add. 12.5mm rear wheel spacers ($125) and you'll have improved looks and better handling while retaining the adaptive suspension all for ~ $500.
Adding the rear diff will definitely help but it's $3200 installed. |
03-09-2016, 12:05 AM | #6 | |
204
Rep 757
Maybe Dinan Engineering can chime in |
03-10-2016, 02:44 AM | #7 |
1777
Rep 4,515
H&R do a low drop set of springs for M235i circa -15mm all round - no need to change bumpstops etc etc - will improve cars road manners and looks without trashing the ride or wheel travel.
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
03-19-2016, 09:57 PM | #9 |
94
Rep 356
Is this a custom order, or something I can order up now? I like the idea of a 15mm drop, and also the M4 LCA setup. Seems price effective.
03-20-2016, 03:40 AM | #10 | |
284
Rep 566
http://web1.carparts-cat.com/default...6107001&12=130 Certificate: http://www.dvsegmbh.info/PDF/einbau/...1468/28896.PDF |
03-22-2016, 11:02 PM | #11 |
94
Rep 356
03-22-2016, 11:08 PM | #12 |
1399
Rep 5,262
you just need a screw driver and keep turning till the height is right
07-12-2016, 01:37 PM | #14 | |
127
Rep 765
On that note, a number of owners have had okay experience with the HR springs. However, the HRs destroyed my adaptive struts (all four started leaking after install). Could be a fluke, but I have heard of this more than once.
"Nothing in the world is more dangerous than sincere ignorance and conscientious stupidity." MLK Jr.
07-12-2016, 07:46 PM | #15 | |
284
Rep 566
07-13-2016, 09:35 AM | #16 |
1777
Rep 4,515
KW HAS m2 kit retrofit onto M235i....
http://f87.bimmerpost.com/forums/sho...2&postcount=11 Anyone know if the strut tube diameter is the same for M235i and M2 ???? If so then KW lower support could also fit on M235i OE strut
07-13-2016, 11:26 AM | #17 |
127
Rep 765
Your statement was that if you replace the adaptive suspension, they "won't work correctly." Point being is that if you install coilovers that are not designed to adapt, then they do indeed work correctly. The adaptability while in motion only applies to very few struts/coils other than OEM setups.
07-13-2016, 11:10 PM | #18 | |
284
Rep 566
To that end, I think, just a thought, that a minimum requirement to produce a similar quality of damping and provide a similar level of wheel contact with the road as the stock adaptive dampers would be a 1-way adjustable kit with a helper spring because a basic preset rebound/compression damper with a basic spring would only be good in a narrow range of conditions. At the same time, using a damper that doesn't utilize the acceleration sensors inputs and VSS capabilities and come with EDC is going to significantly alter the steering inputs and car's handling. I experimented with it a bit in winter. Glad I did that in winter because driving the car on slippery roads made feeling the difference a lot easier. The grip was a bit worse than stock but the car handled like cr*p. I can see how adjustable rebound and a helper spring could remedy the grip part of the equation. The handling part, though, has less to do with the quality of damping. It's the steering inputs that you no longer have. VSS effectively masks understeer and you no longer have that, just as you no longer have the feedback about the position and motion of your front wheels. I suspect that not using those sensors may also affect other things, like braking applications on individual wheels, etc. As a result you have a very flat car that misleadingly feels solid and quite planted when you drive on dry and flat asphalt, it gets worse when you hit road imperfections and if there's not enough traction it can be attributed to the limits of the specific non-oem damper used, but once you try to maneuver and quickly change directions you can no longer do that as quickly or effectively, you no longer have the agility of the stock suspension which has everything to do with the disabled steering functions. Once you get on a slippery patch of road it gets tricky, trying to tuck the car in the same corner you just did on adaptive suspension results in tremendous understeer that then quickly changes into snap oversteer. Catching the car all over the road like that is just no way to go. The steering feels quite disconnected. I certainly didn't try every possible scenario, so, yes, take it with a grain of salt, but no, do not disregard unless you want to end up in a ditch. Coding it out will sure prevent fault messages from popping up but will it remedy the steering? Anyway, that's why I think that using a kit that's not specifically designed to work with EDC and everything that comes with it is a bad idea. It only "kind of" works. Last edited by x233; 07-14-2016 at 12:16 AM.. |
07-14-2016, 07:09 PM | #19 | |
157
Rep 580
07-27-2016, 07:24 AM | #20 | |
127
Rep 765
I also agree that is a bad idea, or at least less preferred for anyone who may do track time (HPDE), or autobahn/European driving - the feedback will be less than stellar which will cause under/over corrections by the driver. For US street use, my guess is 90% of owners would not even notice a difference. I think that is where the danger lies as well; these kits will not scale appropriately for extreme use or 9/10ths driving.
08-01-2016, 10:39 AM | #21 | |
715
Rep 1,541
So how do the cars without the adaptive suspension from the factory handle the steering inputs? I bet they don't and neither does the adaptive suspension.
08-02-2016, 09:58 AM | #22 |
920
Rep 5,538
