03-02-2008, 01:05 PM | #1 | |
Dr. Octagon
260
Rep 1,919
Front Reflector Delete
Over the next couple weeks while my car is on the boat, I will be researching options for a clean solution to the U.S. front amber reflector problem. As most of us are aware, the reflector is secured through a hole in the bumper. After the vehicle arrives, I'll have the actual OD measured to finalize the solution...
Here were my first thoughts: get touch up paint and apply to a plug that will fit nicely... blank plug link similar to: bumperplugs.com I also thought about retrofitting a PDC sensor to cover it. Quote:
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB |
03-02-2008, 01:32 PM | #2 | |
20
Rep 1,504
03-02-2008, 01:39 PM | #3 |
Dr. Octagon
260
Rep 1,919
NOooooooo!
Thanks for posting Randy, that changes everything. ...funny I remember seeing that pic before, but I didn't remember seeing the void area as I do now. I imagine the immediate solution is now down to two options: body shop for fill & paint paint the reflector & replace
OC ///M
2013 E92 M3 Individual Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB Last edited by OC ///M; 03-02-2008 at 02:28 PM.. |
03-02-2008, 01:46 PM | #4 |
152
Rep 493
Drives: '23 M4 G83; '23 M850i
I will order spray paint/clearcoat from BMW and just paint them. Wonder how difficult removal is.
03-02-2008, 02:07 PM | #5 |
24
Rep 438
Painting the reflector then seems to be the only reasonable solution - body shop fill and paint won't be practical for anyone wanting to do a clear bra.
Would poking a hole in the clear bra when I put it back on be a problem? Otherwise would need need a prepainted reflector or get it painted and wait a couple days before clear bra. |
03-02-2008, 02:11 PM | #6 |
Dr. Octagon
260
Rep 1,919
nechron: If you're talking about the vinyl version of clear bra, just have them cut out around the reflector when they apply it, so it's a non-issue. I usually go for the spay-on method, it doesn't yellow and you won't have any lines on the hood.
OC ///M
03-02-2008, 02:16 PM | #7 | |
20
Rep 1,504
At any rate, I think the best option is removing the reflector and spraying it with base coat and clear, and then reinstalling it. I think it pops out pretty easily. Thank US DOT for the reflectors, the product of a multi-million dollar study I'm sure. |
03-02-2008, 02:17 PM | #8 |
374
Rep 8,033
This is the option that makes the most sense. It can't be that hard to pull one out. They must be snap-fit parts.
However, if you send me a $750 check, I will send you CF replacements that will look cool and make your car go much faster than you can imagine. |
03-02-2008, 05:51 PM | #10 |
19
Rep 125
Bimmian used to sell a painted reflector for the E46 M3... I've sent them an email to see if/when they will have these available...
03-02-2008, 06:58 PM | #11 |
348
Rep 2,937
Drives: 2013 Estoril 328i M Sport
These are just like the reflectors on the 08 M5. They're double sided, meaning they're two separate pieces connected to each other (front and back). Be VERY CAREFUL removing them, as I snapped the M5's reflectors while trying to gently remove them. I'm going to have them removed, painted, then snapped back on. It'll look perfect that way.
And Mark, the hole holding the reflector is the same size and shape as the reflector. No plugs will fill that thing. |
03-02-2008, 09:20 PM | #12 |
1912
Rep 4,128
Drives: M235i & G30 540i
Many different options. I'll wait for others to do their own then choose whats best for me by the results of others. Painting them seem to be the best option thus far.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta https://www.instagram.com/bmwm_life_/ https://www.instagram.com/autogiftua/ https://www.instagram.com/phoenixbmwlife/ |
03-03-2008, 12:00 AM | #13 |
33
Rep 657
Sounds like not too many E46 M3 owners on this thread? This was a pretty big annoyance on the e46, and the top solutions are simply clean body work (expensive), order euro bumper (expensive), paint (cheap), or clear reflectors(no thanks).
Bumper plugs will not work. Same as on the e46, they are not circular holes, rather stamped outlines of the reflectors. Anyhow, painted reflectors are fine, it just comes down to getting this done by yourself or buying from somewhere Bimmian, that simply paints the OEM reflectors. I'll call tomorrow and report back what they have to say. I'm sure they will produce these soon enough, i just hope the lag is not too long. |
03-03-2008, 01:14 AM | #14 | |
Dr. Octagon
260
Rep 1,919
...and thanks for the recap. Everything you posted has already been discussed more than once and starting like 10 posts back. I guess now I have to go back and edit my OP so we don't get any more "Hey idiot, bumperplugs won't work" posts... /thread
OC ///M
03-03-2008, 01:52 PM | #15 |
33
Rep 657
Chill out bud, just trying to help out. Never said you were an idiot, simply commenting on something you posted.
What I posted was intended, as it was meant to reiterate the previous comments as some seemed to lack experience over this subject. Sorry you felt that I was implying your idea was retarded; no need to be defensive, this is in fact a messege board
-Dave
2008 E92M3-Space Gray Eisenmann Sport Exhaust_MT/Loaded Last edited by DJ9; 03-03-2008 at 03:30 PM.. |
03-03-2008, 02:35 PM | #16 |
575
Rep 2,099
I purchased the Bimmian painted reflectors for my Carbon black E46 M3. Prefect match. Very happy with them. Hope they produce them for the new E92 M3.
03-03-2008, 05:14 PM | #18 |
Commander-In-Chief
2067
Rep 8,898
Painted reflectors
I'd just get some from someone who specializes in this. For the E46 two were Bimmian and Evosport. However, may be a little while until they are available.
03-03-2008, 08:47 PM | #19 |
Dr. Octagon
260
Rep 1,919
DJ9: My apologies. Sounds like I took it the wrong way. I believe I may have been posting while intoxicated last night.
I wonder how soon the dealership's parts depts. would stock the spare reflectors...
OC ///M
03-03-2008, 08:54 PM | #20 | |
Dr. Octagon
260
Rep 1,919
So if they'll do it, I'd say yeah.
OC ///M
03-03-2008, 09:06 PM | #21 |
24
Rep 438
ahh, i actually asked about that too - they said they NEVER drill the front license plate holder so it wasn't even an issue - not sure how common this is.
AW/FR e92 M3
03-08-2008, 04:05 AM | #22 |
69
Rep 2,385
what about putting vinyl??
E90 06 325. AW. BEIGE. CF WRAP. SMG KNOB. BLACKLINES. MTECH. HARTGE JAPAN REP LIP. ACS CF ROOF SPOILER. CSL TRUNK. KWV2. LE37.
