02-17-2016, 06:14 AM | #1 |
7
Rep 53
Automatic Lights
Hi
I am advised by BMW Genius that when the light switch in the Automatic position there are two light detections levels. In the lower level i.e. less dark then the sidelight come on but no indicator lights are shown on the dashboard [ which seems rather odd to me] and at the higher level i.e. when it is darker the dipped headlights come on and a lights are shown on dashboard display [ which I have seen] If anyone can shed some light on this issue ..sorry about that...it would be most appreciated. |
02-17-2016, 08:26 AM | #2 |
7433
Rep 11,843
Drives: MY24 G01 AW Msport
if light symbol shows up on cluster, your headlights are on- in auto mode.
what do you mean sidelights??? |
02-17-2016, 09:13 AM | #3 |
268
Rep 1,597
I think the Genius was trying to explain that during the day your DRL's (angel eyes) will be on and when light fades the car will automatically put your dipped headlights on.
Current: VW Transporter Sportline, F48 X1 20i M Sport. Previous: F10 530d M Sport, W176 A200 CDI AMG Evolution, E70 X5 3.0 SD M Sport, F20 120d M Sport, E81 120d M Sport, E46 325i M Sport, E46 318ci & Many Others...
02-17-2016, 09:44 AM | #4 |
7
Rep 53
I mean the lights that you get when you use parking lights i.e. the outer ring on the two headlights plus the strip of lights above the headlights. Hope this helps.
02-17-2016, 09:46 AM | #5 |
7433
Rep 11,843
the rings are lit all the time if you set them as DRL, and if your headlights go on they remain lit.
i hope that helps lol |
02-17-2016, 09:48 AM | #6 |
7
Rep 53
Thanks Are you saying that in the A position the DRL `s are on all the time? And what are the DRL`s? And if so what is the O position for?
02-17-2016, 09:51 AM | #7 |
7433
Rep 11,843
DRL is daytime running lights.
angel eyes/outer rings light up as DRL:you can turn them on IDRIVE settings under lighting. they will remain on if you keep them in A or O |
02-17-2016, 10:00 AM | #8 |
7
Rep 53
Thanks for that . Have just checked and as I suspected there is not an option for selecting DRL`s! Maybe because not requirement in UK?! Still confused!
02-17-2016, 10:03 AM | #9 |
7433
Rep 11,843
well do you have Halogen lights or LED headlights..
02-17-2016, 10:08 AM | #11 |
7433
Rep 11,843
my wife has 16 x1, i will look into it tonight it may be differ if you have EURO spec. |
02-17-2016, 10:47 AM | #13 |
268
Rep 1,597
It's a legal requirement to have DRL's on all the time in Europe so I believe that newer BMW's do not have the option to switch them off. My previous E70 did, however I haven't even checked my F10 as I like them on...
Therefore Auto and 0 just determine whether your headlights come on automatically or whether you want to manually operate them
02-18-2016, 04:44 AM | #14 | |
7
Rep 53
