02-16-2016, 07:59 PM | #1 |
81
Rep 308
Drift?
Anyone out there drift f30?
Ive drifted a manual 350z but not auto bimmer. How do you guys drift f30 auto? Ebrake cable (cable or hydraulic?) and evrake pad strong enough to withstand constant stress over time?
F30 328i sedan
02-17-2016, 06:01 AM | #2 | |
1610
Rep 3,945
Great post. You fail. Fast and Furious is only a movie... |
02-17-2016, 06:07 AM | #3 | |
81
Rep 308
I take it on track
F30 328i sedan
02-17-2016, 06:23 AM | #4 | |
1610
Rep 3,945
"Drifting" an auto would be similar to a manual car. You should be able to manually select the gear you want to be in on the auto. |
02-17-2016, 06:32 AM | #5 | |
81
Rep 308
Im new to bmw and was curious what other f30 drifters are doing with ebrake (modification?), techniques and whatever. Every car handles differently. I didnt know this was something i would be bashed over man
F30 328i sedan
02-17-2016, 06:40 AM | #6 | |
1610
Rep 3,945
Anyways, you basically have 2 problems: 1. Power/torque on the 328i. 2. Open differential/lack of a limited slip rear diff |
02-17-2016, 06:49 AM | #7 |
81
Rep 308
i know that and was curious to know what they are doing to overcome those issues. Suspension setup, technique and such. Also i came from v6 so its quite different from 328i with turbo.
F30 328i sedan
03-21-2016, 11:42 AM | #8 | ||
606
Rep 1,782
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
03-21-2016, 01:56 PM | #9 | |
606
Rep 1,782
04-10-2016, 06:36 PM | #10 |
243
Rep 497
ROFL.
Seriously though DO NOT pull the E brake while in gear on an automatic!!! Where exactly do you envision the drive train is going to slip between locked wheels and a running engine. |
04-10-2016, 06:41 PM | #11 |
1610
Rep 3,945
04-11-2016, 10:11 AM | #12 |
451
Rep 469
Nothing happens. I tried it once at low speed on a ice track to see how the car reacted. My car nicely asked me to put it down again because I was driving. Then I tried the same at 50mph and got the same message.
DD: F48 X1 xDrive25i '20 - https://f48.bimmerpost.com/forums/sh....php?t=1703083
For fun: F22 M240i '19 - https://www.2addicts.com/forums/show....php?t=1644646 Previous BMW: Fully loaded F30, 335i https://f30.bimmerpost.com/forums/sh....php?t=1681247 |
06-20-2016, 03:26 PM | #13 |
271
Rep 476
The main obstacle when trying to drift an F30 is the open differential (E-Diff). This essentially means that power is sent to the wheel encountering the least resistance. With the DSC off, you will end up with one spinning wheel. With the DTC or stability systems on - the car will try to apply brakes to individual rear wheels in an attempt to transfer power. Either way, you will find it extremely hard to hold a drift.
06-21-2016, 08:35 PM | #14 | |
1610
Rep 3,945
06-24-2016, 11:41 PM | #15 | |
81
Rep 308
This way i dont have to try to keep the RPM up for instant boost all the way
F30 328i sedan
