Which bump stop to use for Billstein b12 pro kit?
02-13-2016, 06:23 PM | #1 |
99
Rep 254
Drives: 2022 M3, 2023 X3
This morning I installed just the rear shocks and springs due to time constraints. These are the B12 shocks with eibach pro springs. My car is non-sport 2007 335i so this should give it a mild drop. My question however is which bump stop & dust cover should be used? The bavauto howto video shows reusing the stock bump stop and cover but they were not changing springs. So I threw it back together that way for now and not driving it. See attached pics for the difference in travel with each stop, it's about 1 1/4" more with the new stop.
MINE: 2022 M3Cx, Sky Grey, Driv/Exec/Park/Laser
1/26 Ordered, 4/26 Prod, 5/4 Assembly, 5/9 Port, 7/11 Transit, 8/3 Port, 8/18 Dealer, 8/25 Delivered WIFE: 2023 x3 m40i Last edited by Rosetta Stoned; 02-13-2016 at 06:49 PM.. Reason: fix attachments |
02-13-2016, 08:51 PM | #2 |
1904
Rep 6,968
Drives: 2007 Black/Black 335i e90
You don't use a bump stop. The bump stop is built into the strut.
I am assuming you changed out the upper/ upper & lower/ upper shock mounts for the rear. The front, you should change out the strut bearings/ mount. The car will take about 2,000 miles to fully break in and settle the new suspension. At that time, you will need to get an alignment done. The rear should have came with a bump stop inside the dust cover. I would use the one provided. |
02-13-2016, 10:58 PM | #3 |
31
Rep 138
Drives: 2010 328i Touring
Use the Bilstein supplied bump stop, NOT the OEM in the rears. As you have it shown, it's the Bilstein supplied bump stop, washer, then the blue boot over it. I have the same B12 kit. For what it's worth there are no bump stops in the front, as its internal to the Bilstein strut. Same as what came up in the thread below.
Bilstein B8 (sports) installation help http://www.e90post.com/forums/showthread.php?t=1202520 |
02-14-2016, 08:51 AM | #4 | |
840
Rep 2,402
He's clearly talking about the rear shock, not the front strut.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
02-14-2016, 10:16 AM | #5 |
99
Rep 254
Thanks for the replies! Yes this is the rears only right now and I put new upper and lower mounts along with spring pads. I'll be doing the fronts next weekend, spending valentines with the wife and kids and not in the garage today.
1/26 Ordered, 4/26 Prod, 5/4 Assembly, 5/9 Port, 7/11 Transit, 8/3 Port, 8/18 Dealer, 8/25 Delivered WIFE: 2023 x3 m40i |
02-16-2016, 03:26 PM | #6 |
99
Rep 254
Just to add to the confusion I had about it. Bavauto who supplied the strut&spring kit replied back saying to reuse existing, turner motorsports who supplied the install kit said to use new ones. I'm going with the new ones but figured I'd mention that in case someone else happens to search as I did. As mentioned this is for the rears only since the fronts have integrated stops.
02-16-2016, 03:48 PM | #7 |
255
Rep 2,547
I spoke with a rep from bilstein when I installed mine as well as turner and Bavauto they all said use the bilstein supplied bumpstops. I did and they work great.
