Aftermarket Pre-LCI Bumper vs LCI
02-11-2016, 08:00 AM | #1 |
44
Rep 238
I have an e90 335i xdrive LCI and was wondering if aftermarket pre-lci bumpers (mtech, m3 rep, etc) would fit the LCI. I remember seeing that the tabs for a pre-LCI to LCI conversion were possible but haven't seen anyone do the other way around. Reason I ask is because pre-LCI bumpers are consistently cheaper than LCI for the same exact bumper basically. Can anyone shed some light on an LCI using a pre-LCI aftermarket bumper?
2009 Monaco Blue BMW 335 XDrive, Beyern 18s, KWv1, MHD, VRSF Full, ARM FMIC, BMS DCI, Stett CP, Forge DVs, Stage 2 LPFP, BMS OCC, (soon) M3 Rear Sway, VTT Stg 2, MMP Inlets
02-12-2016, 12:42 AM | #2 |
Where'd my VTEC go?
481
Rep 6,067
Hood and grilles are different on LCI.
The mounting points on the bumpers are the same, but unless you change out the hood and grilles it will look whack
02-12-2016, 12:43 AM | #3 | |
44
Rep 238
02-12-2016, 03:14 AM | #4 |
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
You have lci, but to use a pre-lci bumper you'd also need to change to a pre-lci hood and kidney grills
02-12-2016, 10:44 AM | #5 | |
44
Rep 238
