02-10-2016, 02:54 PM | #1 |
BimmerPost Supporting Vendor
24163
Rep 190,725
2016+ BMW 340i/ix B58 Billet Intake - Gains up to 8 whp
This billet plug and play air intake system unlocks up to 8 whp to the wheels from your B58 engine. In addition to the extra power throttle response, turbo spool, and sound are dramatically improved, finally allowing you to hear your turbo spool up under heavy acceleration. The system is CNC machined from billet aluminum, anodized black for a clean look and includes a reusable S&B high flow filter. The OEM cold air intake tube and insulating base remain fully functional. Install takes only minutes and is fully reversible. Install Video
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 02-17-2017 at 02:26 PM.. |
02-10-2016, 08:37 PM | #6 |
105
Rep 146
Drives: BMW's
Garage List 2020 G07 X7 [0.00]
2013 E70 X5 [0.00] 2003 E46 M3 [0.00] 2013 F10 M5 [0.00] 2009 E90 335ix [0.00] 2009 E90 M3 [0.00] |
Anyone else seeing that throttle spacer with a possible meth line? Can't wait to see what numbers that'll make
02-11-2016, 01:40 AM | #8 |
142
Rep 931
15WHP !?!?!?
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
02-11-2016, 03:16 AM | #10 | ||
1777
Rep 4,515
You are mis-representing the gains this intake brings. 15whp gain is nearly double what what BMS quote:- Quote:
http://www.n54tech.com/forums/showpo...&postcount=153 Suggest you revise your post or moderators delete it asap BP
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI.. |
02-11-2016, 03:25 AM | #11 | |
24163
Rep 190,725
Everything written in the subject of the first post is copied directly from Burger Tuning website. I did not rewrite any of the words. Not sure why you are accusing me of mis-representing when i only copied what the manufacturer wrote on their website
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 02-11-2016 at 03:36 AM.. |
02-11-2016, 03:26 AM | #12 | |
24163
Rep 190,725
Everything else is directly from Burger Tuning website
02-11-2016, 04:28 AM | #13 |
Moon Parasite
654
Rep 1,336
If I'm seeing their dyno chart correctly, and please correct me if I'm wrong, the first dyno run is not stock but using a JB4 on map1. Then they show the gains of this intake on a dyno run marked as with JB4, a downpipe, and running map 2. If this observation is correct, then touting product gain when the testing conditions are not exactly the same seems incorrect. The intake should have been the only change with the car staying in map1 for an actual look at any delta or showing the dyno run on map2 with /DP, first without, and then with the intake. I guess saying a product has "up to" X gain is the way to answer that.
Also noted this is the data being provided by the manufacturer, not Mike.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
02-11-2016, 05:12 AM | #14 |
1913
Rep 2,210
Drives: '17 jackrabbit on crystal meth
^and that's why the title reads "up to" 15whp
But you're right. How much of that 15whp stems from the increased map 2 boost and downpipe?
2017 BSM M2|6MT|Exec|black kidneys and gills|full alcantara wheel|CF spoiler|Dinan Stage 4|Dinan COI|Dinan free flow exhaust with resonator delete|Fabspeed sport cat DP|BMS clutch stop|465 bhp|4.75/5 stars
retired: 2014 435xi|MPPK|335 bhp|3/5 stars |
02-11-2016, 08:31 AM | #15 |
1777
Rep 4,515
my point is, you will not gain 15whp from this intake alone.
BMS state 7-8whp from just the intake......
02-11-2016, 08:34 AM | #16 |
660
Rep 1,059
Huh. So Map 1 is the baseline and Map 2 is the "test run" with higher boost, and a downpipe, and the intake. Quite the apples to apples comparison . So again, on the B58, an intake is just another sound enhancer with minimal gains on a mostly stock car. I'm sure at much higher HP levels, an intake will make a difference, but not here.
02-11-2016, 08:43 AM | #17 | |
1777
Rep 4,515
Either this or offer to supply / fit and dyno one on a B58 FoC so as you can back up yours/BMS claims
02-11-2016, 08:47 AM | #18 | |
1777
Rep 4,515
http://www.n54tech.com/forums/showpo...35&postcount=1 Pump gas - baseline B58 bone stock - 331whp and 339wtorq Pump gas - bone stock + JB4 Beta map 1 - 379 / 378 Pump gas - BMS Intake + decat Dp + JB4 Beta map 2 395 / 405
02-11-2016, 09:37 AM | #19 | |
4912
Rep 115,980
We'll get a Baseline then just filter one. Mike |
02-11-2016, 10:08 AM | #20 | |
24163
Rep 190,725
They are looking into this issue.We will post an update to the info provided very soon.
02-11-2016, 10:14 AM | #21 |
24163
Rep 190,725
Bee Pee You are correct the gains from this intake on its own is 7-8 whp
It should be noted that the main advantage of this intake is sound and spool improvement I will change the thread title to reflect the correct gains. We and Burger will both be changing the claimed gains on our websites as well.
