02-09-2016, 04:58 PM | #1 |
Supreme Allied Commander
3776
Rep 54,162
Drives: F80 M3
Ohlins R&T for your F2x F3X RWD & X-Drive BMS MU00 - Worldwide shipping!
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. BMS MU00(Worldwide) or BMS MU00S1(USA) General > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year Limited Warranty Front > McPherson Strut > Single bleed adjuster > Spring preload adjuster (approx. 20-30 mm lower than standard > Coil Springs (rate 80N/mm) > Dustcovers > Use with original top mounts Rear > Conventional Shock Absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 20-30 mm lower than standard) > Coil Springs (rate 140 N/mm)(Additional springs at the rate of your choice will be supplied at no additional cost) > Dustcovers > Use with original top mounts F2x F3x (X-drive and RWD) 1-series (F20,F21) 2-series (F22,F23) 3-series (F30,F31,F34,F35,G20,G21) 4-series (F32,F33,F36) Landing Stateside in August. ***Vehicle with EDC will need to have EDC coded out*** ***We can ship the standard kit worldwide at a very discounted rate. PM us your address for a quote!*** BMS MU00S1 $2990 Order here: https://hpautosport.com/product/ohli...es-bms-mu00s1/ Spindle housing spreader tool: https://www.amazon.com/gp/product/B0...ea68a402602f82 Last edited by HP Autosport; 07-09-2023 at 10:09 PM.. |
04-11-2016, 09:35 AM | #3 |
Rep 18
Hi HPA, I'm pretty interest and was doing a little bit of research on the Ohlins
Just realised the part number of the F22 kit and spring rates are the same as F30 kit. Is this supplied kit for F22 or F30? |
04-11-2016, 10:27 AM | #4 | |
3776
Rep 54,162
Drives: F80 M3
Spring rates in the case of the F2x could be a bit high for street use. We offer a 20% discount on Swift springs of lower rates if prefer them. |
11-22-2016, 11:32 PM | #21 |
3776
Rep 54,162
Drives: F80 M3
