02-05-2016, 02:12 PM | #1 |
Rep 14
6NS enhanced bluetooth and HU_NBT2
Has anybody with the newer HU_NBT2 module been able to successfully code in 6NS enhanced bluetooth?
I was able to VO code this option on my '16 and I now have the office menu as well as a new input on the media screen that appears to be for the snap-in adapter but I don't get the office checkbox in bluetooth settings nor am I able to get parallel phones working. I do see a small number 1 symbol next to the connected phone but there is no option box for phone 2 in the configuration screen. |
02-08-2016, 07:20 AM | #2 | |
10
Rep 47
HU_NBT_EVO > HMI 3000 > HMI_36_36_8 = aktiv. As soon as that was changed to active, I could not bluetooth stream audio, I lost the second phone, lost ring tone and could not use office. I am guessing, purely a guess, is that there is a check for the additional hardware related to 6NS that is not present in 6NH. Make all of these Aktiv except Single_or_Multilink. Make that Multilink. Bluetooth_2nd_HFP Two_Phones_parallel SINGLE_OR_MULTILINK API_USB_VIDEO ENT_VIDEO CALENDAR_EIN_AUS CONTACT_BOOK_PICTURES DATACOMM_CSIM EMAIL_EIN_AUS MACRO_PIM PIM_BILDER_EIN_AUS REMINDER_EIN_AUS SMS_EIN_AUS TASK_EIN_AUS TEXT_NOTES_EIN_AUS AUDIO_NOTES_EIN_AUS PIM_NEW_ELEMENT_AUDIO_NOTE PIM_NEW_ELEMENT_VOICE_EMAIL Inband_ringing |
02-13-2016, 09:03 PM | #3 | |
Rep 14
02-18-2016, 07:02 AM | #5 |
Coding ECU's remotely
439
Rep 1,169
Have you changed your phone settings in your actual phone to allow messages over bluetooth?
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
02-19-2016, 07:37 AM | #6 |
Rep 35
I have a UK Sept 2015 M135i and can't get it to work.
All FDL settings above are correct and the VO has definitely changed. I'm beginning to think that it might be the iphone6 that might be the problem. I've deleted it on the car and phone and re-paired etc but the option on the phone to show notifications never appears and only get audio and telephone tick box options on the Idrive ,though it does work in my wife's 2012 E70 x5. Just about ready to give up. |
02-27-2016, 02:20 PM | #7 |
Rep 29
I'm having the same problem with my 2016 F30 340i. I changed FA to 6NS and then VO coded the HU_NBT2.
The office menu shows up but I am unable to get messages to show up in the office menu or turn the feature on either in my phone settings (iPhone 6) or in the BMW phone setup. BT audio streaming works just fine as it did before I re-coded the FA. I get a '1' next to the phone but if I add my wife's iPhone it also shows '1' and it seems as though parallel BT phone is not working. Is it possible we need a newer CAFD to get this working? I asked for additional assistance on this over in the usually very active coding forum at Bimmerfest but nobody there has offered any input on the problem. I'm reluctant to code additional parameters as it seems it may or may not address the issue. |
02-27-2016, 06:54 PM | #8 | |
Rep 25
02-28-2016, 11:15 AM | #9 | |
Rep 29
I'm going to post the coding logs over at Bimmerfest coding forums and see if anyone can help figure it out. |
02-28-2016, 11:27 AM | #10 |
1398
Rep 5,262
02-28-2016, 12:36 PM | #11 |
Rep 29
02-28-2016, 12:50 PM | #12 | |
1398
Rep 5,262
http://www.2addicts.com/forums/showt...9#post19345399 |
02-28-2016, 01:14 PM | #13 | |
Rep 29
Bluetooth Audio on the 2nd line. No other lines. |
02-28-2016, 01:45 PM | #14 |
1398
Rep 5,262
02-28-2016, 02:12 PM | #15 |
Rep 29
02-28-2016, 03:00 PM | #16 | |
1398
Rep 5,262
can you post a photo of your configure bluetooth screen? |
02-29-2016, 09:13 AM | #17 |
Rep 29
Yes, somehow after VO coding this option is not showing up. My car just got a TSB for reprogramming at the dealer so it is possible that theFW version on the at is causing problems with this working now.
02-29-2016, 04:17 PM | #18 | |
Rep 25
How do you get to that first screen? The second screen is how mine looks also, but when I re-pair my phone I get a notification on the phone asking if I want to share contacts and messages. After I allow it, I then get some of my text messages populated in office, but no new messages show up. I thought it was probably because I switched to Google Fi and now use Hangouts as my SMS app, but now I'm wondering if there is a setting somewhere in the car I need to change?
02-29-2016, 04:20 PM | #19 | ||
1398
Rep 5,262
02-29-2016, 05:19 PM | #20 | |
Rep 25
Office (not checked) Show Images (checked) Telephone 2 (not checked) so I checked the Office option, removed my phone, added it back, then clicked allow on contacts/messages when the notification came up on my phone. Went back into that same screen above and office is still checked. Went back to messages and it re-downloaded the same messages it was displaying before (nothing newer than 10/2015). Strange... |
02-29-2016, 05:37 PM | #21 | |
1398
Rep 5,262
03-01-2016, 11:18 AM | #22 | |
Rep 35
Don't get office box to tick on the Idrive with iPhone 6 There must be another value to change that is not in older versions? |
