02-02-2016, 08:35 PM | #1 | |
122
Rep 444
Finally got the TPMS disabled and FTM activated!
Since I plan on ordering a couple sets of wheels and tires for the summer, road course and drag, I really didn't want to spend almost a thousand dollars on TPMS sensors. I read a bunch of posts saying it was not possible, but thanks to member stu14t , I've sucessfully disabled TPMS and activated the FTM.
These directions and all work was done by him. I even messed up a couple things but he helped me though it. Quote:
Quickest Stock Turbo F8x In The World
02-02-2016, 08:53 PM | #2 | ||
1399
Rep 5,262
The advantage of writing it though is that if the dealer does an update the car will be coded without the option you removed from the FA so your tpms decoding will stay, else it will get wiped out as the dealer will code the car with the options specified on the FA |
02-03-2016, 01:58 AM | #3 | |
451
Rep 1,201
This was not all my own work, I had help from wibbles too, so some credit to him. Many thanks to InTheSound for the US / CAN workaround for this How to guide added below
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d Last edited by stu14t; 04-18-2016 at 02:30 AM.. |
02-03-2016, 02:34 PM | #4 | |
1399
Rep 5,262
02-03-2016, 05:03 PM | #5 |
451
Rep 1,201
Please do. Exactly what these forums are for
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
02-15-2016, 04:37 AM | #6 |
122
Rep 444
Just wanted to update. I've swapped my rims to ones without TPMS and it's still working beautifully. Thanks again to Stu14t, pikachu and everyone else that helped me get it working.
02-15-2016, 11:38 AM | #7 | |
1399
Rep 5,262
BTW what wheels/tires did you get ? I thought about not doing TPMS on the dedicated set but it was only $65/ sensor, about $260 for all the wheels and it's actually quite useful to check psi and temp when on the track so you know where you are at... |
02-15-2016, 10:38 PM | #8 | |
122
Rep 444
Just like the fact that we can turn them off now since I'm going to have my street set, track set, and a drag set. 12 new sensors is pricey.
04-12-2016, 10:14 AM | #10 | |
9
Rep 46
Can you attempt a reset in iDrive again? Does it still reset to green on all four wheels for RPA? I may go through the grunt work an swap back to the wheels with sensors and do the coding and see if I end up with a different outcome. |
04-16-2016, 06:26 PM | #11 |
9
Rep 46
Swapped wheels back to stock today (w/TPMS) and performed VO coding back to TPMS. Reset tire pressure and got all 4 green tires within seconds of moving vehicle. Coded back to FTM and tested a reset. Got all 4 green within seconds. Things looking good!
Not so fast. Now for the final test. Re-mounted the wheels without TPMS and performed a FTM reset. Not going green and I'm expecting TPMS Malfunction in no time. Not sure if there is any other coding that should be done, but my theory is the TPMS hardware actively communicates with the ECUs even when the car is coded FTM (RPA). Without the sensors, I can't get the reset to work even for Flat Tire Monitoring (ABS rolling test for pressure). |
04-17-2016, 09:53 PM | #12 |
9
Rep 46
SOLVED!
Solved for Canadian Spec m235i (2014) http://f30.bimmerpost.com/forums/sho...5&postcount=48
09-18-2023, 05:58 PM | #14 | |
Rep 12
Drives: BMW M2
First ever attempt at coding and I successfully modified the FA/VO and I hit "code" on the DSC ECU only. This generated an FTM failure message. I just went back in and hit code against the other ECUs mentioned the next morning and everything worked as expected. Thank you for saving me money on this. I can also now add this in and out as needed! Last edited by WoodyOGM2; 09-19-2023 at 03:16 AM.. |
12-06-2023, 07:28 PM | #15 |
12
Rep 49
Reviving an old thread here;
Can the tpms be coded as to not interfere while in Sport+? Or can it be coded for a different psi value? |
12-09-2023, 02:10 PM | #17 |
12
Rep 49
