battery change
02-02-2016, 04:03 AM | #1 |
165
Rep 1,059
battery change
Hi guys, so it seems my battery is its last legs. It struggles a lot. Car is using glow plugs even if the temps now are not zero or below.
So it needs changing. I have two options: get one from bmw or get from somewhere else. Question os: Is there any difference between the two? Thanks |
02-02-2016, 05:27 AM | #2 |
24
Rep 355
I got mine from tayna..
Same spec as the OEM one.. 90Ah, 720 CCA.. https://www.tayna.co.uk/EA900-Exide-...5TE-P9593.html Recoded, registered, all working fine.. However, the hinge for the handle on the battery does cause a bit of a seating issue for the +ve terminal, just file off that part..
In Progress: Surround View Retrofit 8TH |
