M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > ET-22 square setup?
      01-27-2016, 03:18 PM   #1
lx93
65
Drives: 16 MT M2
ET-22 square setup?
I am looking for a set of square wheels as dedicated track set for my M2, soon to be delivered this spring. I am thinking of APEX EC-7 18X9.5 et22 wheels with 275/35/18 all around. Will they clear? will ET-22 stick out a lot in the rear?
I do not plan to use spacers due to safety concerns.
      01-27-2016, 05:32 PM   #2
Pyrat 2
Pyrat 2's Avatar
Drives: Rapidly from A to B
unlikely to fit in rear. that's pushing out by 12 mm plus the additional tire width. pictures posted of the rear fender suggest that configuration won't fit. hard to tell though until someone gets in there and starts experimenting.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
      01-27-2016, 07:16 PM   #3
Japper69
United Kingdom
136
Drives: G80 M3 X-Drive - Skyscraper Gr
That's pushing out 18mm at rear plus another 10mm for tyre. The front is also gonna rub.
      01-27-2016, 07:40 PM   #4
Pyrat 2
Pyrat 2's Avatar
12 mm push since the 9.5 inch wheel is 6 inches narrower on each edge than the stock 10 inch wheel.
      02-03-2016, 07:29 AM   #5
Icsunonove
Argentina
10
Drives: M2 BSM
In the back:
18mm (ET 40 --> ET22) + 5mm on each edge (265 --> 275) = 23mm
Package will stick out 23 mm (0.9'') farther.
Most likely it will rub.
In the Font:
Package is 8 mm (0.3'') closer to suspension/brakes components.
7mm (ET 29 --> ET22) + 15mm on each edge(245 --> 275) = 22mm
Package will stick out 22 mm (0.9'') farther.
Check this setup (not square, but..):
BF Goodrich G-FORCE R1 245/45/18 Apex PS-7 18X9.5 ET22 stick out 7mm
BF Goodrich G-FORCE R1 275/35/18 Apex PS-7 18X9.5 ET35 stick out 10mm
Most likely will not rub.
You could try other options here:
http://www.rimsntires.com/specspro.jsp
      02-04-2016, 12:38 PM   #6
metrickid
Dinosaur supervisor
metrickid's Avatar
Netherlands
3030
Drives: E91 318d
From what I can tell from photos the M2 is no way near the offsets the M3/M4 uses on after market wheels even when lowered. So I think we need M2 specific offsets for all wheels.
Appreciate 2
      02-05-2016, 06:20 AM   #7
-JLT-
-JLT-'s Avatar
3446
Drives: '22 X4M COMP, '23 iX xDrive50
I would go with 265 tires squared. u would only have to buy 2 new tires for front. it would be about 18mm more aggressive (push outward) and I believe won't rub, even lowered, if it's offset is close to M3.
I ran 275 all around on my M3 with Apex arc-8 with no rubbing and lowered on springs
-JLT-
      02-05-2016, 05:59 PM   #8
gthal
gthal's Avatar
1904
Drives: 2018 340i xDrive
No one will be able to confirm this for you... it will all be speculation until someone gets an M2 and can get measurements and start test fitting. I would not buy anything until you know for certain unless you are OK with it potentially not fitting.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      02-06-2016, 05:44 AM   #9
Pyrat 2
Pyrat 2's Avatar
I'll be that person doing the tests. I have a small arsenal in my garage of sizes I can check. Different widths and offsets plus 3 and 5 mm spacers for more evaluation. Can't wait.
      05-07-2016, 06:33 PM   #10
TTFS
TTFS's Avatar
130
Drives: M2, F10 M5, E46 M3, E90 M3
I am not sure if this helps anyone. The wheel was 18x10.5 et 27 and it was way too aggressive. I am currently running/ testing 19x9.5 et 23 with 275 and it dead flush and probably rubs if someone was riding in the back seat. We are going to run forged Renn motorsport wheels soon.
      05-07-2016, 11:22 PM   #11
OrangeCrush
OrangeCrush's Avatar
1236
Drives: VO 1M #513/740
What are you running in the front in this pic? Looks pretty good from this view.
Current
AW BMW M2
Past
VO BMW 1M
      05-09-2016, 08:19 PM   #12
TTFS
TTFS's Avatar
130
18x9.5 et35 and 18x10.5 et 27. It is very aggressive unless you are going to run some camber.
      05-09-2016, 09:24 PM   #13
Bavarian Barbarian
18
Drives: 2016 M2
So what would your ideal offset be with 9.5 in front and 10.5 in the back?
      05-10-2016, 07:20 AM   #14
OrangeCrush
1236
According to this, the fronts poke out about the same as stock and only go toward the suspension. If you went with 255's it looks like it would have the same stretch as stock. 275's should be fairly square with 9.5. TTFS , we're there any issues with the wheels/tires rubbing the suspension on the fronts? What size tires did you have? Would 275 work? See below.
Current
AW BMW M2
Past
VO BMW 1M
      05-11-2016, 07:16 PM   #15
TTFS
TTFS's Avatar
130
We are measuring this saturday for Renn motorsport forged japanese wheels this saturday I will see if i can help once it is done.
      05-11-2016, 10:07 PM   #16
supersam
Da Baus
supersam's Avatar
283
Drives: F87 6MT, RA, E46
looking forward, Renn makes some really light wheels. I hope they'll make some fat 18s for us
M2 LBB/6MT/VFstg2/V1 stealth/JRC valve delete/Dinan/
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
      05-12-2016, 08:37 AM   #17
Bavarian Barbarian
18
Drives: 2016 M2
What is the front fitment in this photo? 18x9.5et35? What brand and size of tire?
      05-12-2016, 08:32 PM   #18
Fullofdays
41
Drives: m
Interested to hear what you learn this weekend.
      05-25-2016, 06:43 PM   #19
Fullofdays
41
Drives: m
TTFS Any update on the 18 fitment? Looking for a set of track wheels and will be running GC adjustable camber plates for the track.
m2
