F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > CG Precision DS-1 Race Catted Downpipe - Now Fits 340i!
GetBMWParts
      01-23-2016, 12:39 AM   #1
CG Precision
CG Precision's Avatar
Drives: 2013 BMW 335i
It's finally here......and it's freaking awesome.
CG's DS-1 5" Hi-Flow Race Catted Downpipe for both the 335i/435 F30/F32 and the new 340i!!
  • The only catted downpipe to offer a full 3.5" connection to the exhaust system, resulting in faster turbo spool up and more horsepower*,**
  • Ultra-high flow 200 CPSI race catalytic converter
  • True 5" (127mm) diameter catalyst for 56% less flow restriction and better emissions than 4" sports catalysts used by competitors
  • T304 stainless steel
  • Tig welded with chemical weld passivation for enhanced appearance and corrosion protection
  • 3D computer design and flow simulation with minimized bends and gradual transitions for smooth airflow
  • OEM-like fitment with factory O2 sensor functionality
  • Available for 3.5" (pneumatic wastegate) or 4" (electronic wastegate) turbo connections
  • CNC flanges and precision laser-cut brackets
*Only fits with CG Precisions VS-1 or R-1 catback exhaust system
** Also available with factory exhaust connection flange
NEW PRODUCTION PICS OF THE DS-1 FOR THE 340i!!!
NEW 3D MODEL FOR 340i!!!!
      01-23-2016, 09:25 AM   #2
obriennathaniel
@obriennathaniel_f30 on Instagram
obriennathaniel's Avatar
Drives: 582whp/596wtq '13 335i
Nice!!!! I still need to get my R1 from you guys ��. As soon as I can get the cold start turned off on my car.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
      01-23-2016, 10:05 AM   #3
G30 B58
Pace Car Driver
1548
Drives: '22 AW G30 B58 M-Sport
.....and a 15 minute "No Check Engine Light" guarantee?
      01-23-2016, 10:21 AM   #4
CG Precision
There is a reason our release of this product took us a while. We put in a lot of time engineering and testing what we believe to be a very good solution. One of the advantages of using a large diameter catalyst is that it not only increases the exhaust flow but also the surface area available for gaseous reactions to occur. Additionally, the gas residence time within the catalyst is increased. These factors contribute to better emissions performance. We have datalogged the catalyst performance values monitored by the OBDII system and compared them with the performance of the stock catalytic convertor and a catless DP, we know what the range of values should be and we dialed it in. Our test car has gone thousands of miles with no CEL. On a fully catless DP we are able to trigger it within 5 minutes of driving. We decided it was time to release it to the public so here it is! Give it a try and let us know what you think.
Appreciate 2
      01-23-2016, 04:54 PM   #5
rob_h10
18
Drives: F30 335i
Thank you for replying to my PM.
For the catted dp, do you guarantee there will be no CEL triggered on a stock set-up? What do I do if it happens when I install your catted dp?
When you say 'Our test car has gone thousands of miles with no CEL.' is that completely stock? Have you tested using a piggyback or flash then revert to stock? I'm contemplating my options when it's smog-check time... do you have any insight/recommendations?
      01-23-2016, 05:52 PM   #6
CG Precision
We do not guarantee no CEL will ever show up simply because we do not have the quantity of longterm data required to support this from a business standpoint. Due to our design margins we don't expect you will ever see a check engine light.
Our testing was on a 100% stock vehicle, other than our turbo-back exhaust system. If you are using a piggyback that is set to auto-clear codes you will never be ready, same with a flash as far as I know. If you went back to stock, you would need to wait until the OBDII drive cycle was completed.
While we have put in a lot of R&D to this product we have still priced it very competitively in the market and are listing it below MSRP right now. If you want to wait for other customers to post their feedback that is entirely up to you. If you search through the forums, we have a lot of happy customers on here and I'm sure you would be one as well.
      01-23-2016, 06:36 PM   #7
rob_h10
18
Drives: F30 335i
I'm already one of your satisfied customers. I've had your cat-back system on my car for over a year. I already know the quality of your product rivals other big-name outfits... and even surpasses a number of them.
My current experience with another catted dp from another vendor is sub-par... so that's why all the questions.
I'm getting your dp soon, I just need to decide to pick the right one for me.
      01-23-2016, 06:50 PM   #8
CG Precision
Haha well thanks for clearing that up
If you are concerned about emissions in general I would go with the catted. The performance and sound difference is not noticeable. What is your main deciding factor? If you want to pm me your issues with the current catted dp, maybe I can address them better.
      01-23-2016, 07:06 PM   #9
rob_h10
18
Drives: F30 335i
I'm good... thanks for the offer.
I'm flippin' the coin... I'm flippin' the coin...
I'll decide soon.
      01-23-2016, 07:08 PM   #10
CG Precision
I'll decide soon.
      01-23-2016, 07:08 PM   #11
CntryClub007
CntryClub007's Avatar
490
Drives: 2016 340i | 2015 X5-50i
So what's the price again? Sorry if I missed that.
      01-23-2016, 07:15 PM   #12
CG Precision
PMed!
      01-23-2016, 08:45 PM   #13
_bdiddyb_
215
Drives: 2013 335i
I want one!
      01-23-2016, 08:48 PM   #14
CG Precision
Originally Posted by _bdiddyb_
I want one!
We have one for you!!!
      01-24-2016, 07:25 PM   #15
R32DBP
Drives: 2014 335i M Sport, 2004 .:R32T
What's the price on this?
      01-24-2016, 09:28 PM   #16
CG Precision
PMed
      01-25-2016, 12:48 AM   #17
TANG2864
Drives: 2015 F32 435i Coupe "4DIRTY5"
What is the power difference between this and a catless downpip.? Also, price? I am interested.
      01-25-2016, 08:17 PM   #18
CG Precision
Too little to be accurately quantified. You are looking at maybe 3-5hp less. It is a large high flowing cat, the difference in hp, torque and throttle response compared with a factory dp feels identical to a catless dp.
We can post price in this thread but there is a vendor thread in the sponsor classifieds.
      01-25-2016, 08:31 PM   #19
N55Nick
82
Drives: 435i xDrive
Price? And will this not fit on a stock exaust?
      01-25-2016, 08:36 PM   #20
CG Precision
We have a version for the factory exhaust connection or VS-1 3.5" connection. The VS-1 comes with an adapter flange so you don't have to get the downpipe to run the cat back or vice versa.
      01-25-2016, 10:29 PM   #21
Forgiven
Forgiven's Avatar
122
Drives: 22, X5 45e
Beautiful.
G05 - M Performance roof spoiler
      01-25-2016, 11:34 PM   #22
CG Precision
Originally Posted by Forgiven
Beautiful.
Thanks!
f30post
