219M on LCI e90 xdrive with KW V1??? rear rub?
01-07-2016, 01:09 PM | #1 |
20
Rep 241
will the rear rub if i am going for this setup?
e90 328xi LCI dropped: KW V1 with 1.5 fingers gap staggered 219M F: 18x8.5 et 29 w/ 225/40/18 R: 18x9.5 et 23 w/ 255/35/18 i am pretty sure the front would be ok. But I am wondering the rear. there are mixed comments about it. Is anyone with this similar setup? I don't really wanna roll my fender, so if i guarantee to rub and negative camber won't help, maybe i will get another set of wheels or look for square setup. Thanks. Last edited by armansiu; 01-07-2016 at 01:46 PM.. |
01-14-2016, 09:25 AM | #2 |
37
Rep 504
Drives: BMW 335xi 2011
Roll fenders and negative camber !
BMW 335 xdrive 2011 BSM
BMS Intake, ER CP, ER competition FMIC, N54tuning DP, COBB V2 stage 2+ aggressive, side marker delete, LUX V5, BMW PE, KW V1, Volk Racing CE28N Candy Red (SOLD), Advan Racing RS |
01-15-2016, 12:13 PM | #3 |
20
Rep 241
03-12-2016, 01:49 AM | #4 |
Stock
171
Rep 1,275
Any particular reason u want to avoid rolling rear fenders?
'09 E92 335i (6MT) Jet Black/Coral Red
'11 E90 328i XDrive (6AT) Jet Black/Saddle Brown (wife's car) '06 Evolution IX MR (sold) '06 R6 Anniversary Edition (sold) |
03-23-2016, 12:51 PM | #5 |
25
Rep 382
i have 18x10 265/35 18 et 25 dropped. it rubs once in a while...
fenders rolled tho.. in your case you shoulddnt rub i remember i had 19x9.5 265/30 no rubbing at all.. until i put 12mm spacers lol.. and dropped also |
04-25-2016, 03:09 PM | #6 |
20
Rep 241
ok, 219m installed. kw v1 installed.
Here is the result. without kw v1, no rub at all with 225/255 RE760 with kw v1, rub a bit when no load. rub a lot when 2 adults at the back seat. ROFL Will do my alignment next week for some negative camber angle. Hope it will help. |
04-25-2016, 04:41 PM | #7 | |
Touring cars rock
351
Rep 907
There's absolutely no reason not to roll the fenders, unless you're car is leased. |
04-25-2016, 05:22 PM | #8 | |
20
Rep 241
I will see what will happen with the negative camber and decide. gotta do alignment anyway. |
04-25-2016, 09:19 PM | #9 |
Touring cars rock
351
Rep 907
I've done rears with a baseball bat just as well as the guy with the fancy tool. It's not rocket science. That lip on the inside of the fender is about 1cm, it rolls easily, just make sure you use a heat gun on the paint or it WILL crack.
04-29-2016, 09:34 AM | #11 |
25
Rep 382
pay someone to roll your fenders lol..
its like 60 bucks here in NY.. it looks easy enough to DIY but easy to mess up your fenders also.. |
