Fault Codes CC-ID 24, 35, 50, & 354
12-28-2015, 12:16 PM | #1 |
24
Rep 92
Hi,
Every so often my car displays these four fault codes. It only seems to have on longer journeys. When the car is turned off and on the faults will clear and stay off until a long distance is covered again. Has anyone else had these warnings appear? CC-ID 24 CC-ID 35 CC-ID 50 CC-ID 354 Thanks in advance. Last edited by Todd_77; 12-28-2015 at 12:25 PM.. |
12-28-2015, 01:06 PM | #2 |
175
Rep 1,596
DSC 24 DBC Dynamic Brake Control Brake Assist Failed
DSC 35 DSC Failed DSC 50 Runflat Indicator Failed DSC 354 Start Assist Inactive Basically all those codes indicate some issue with the ABS/DSC system. Need to scan the ABS system for fault codes and find out whats wrong with it. |
12-28-2015, 03:00 PM | #3 |
24
Rep 92
Great cheers. I bought the Carly App a few months ago so will try running it to see if it brings up anything. If not I will borrow a friends computer and plug it in.
I've read people mentioning different things from Brake Fluid levels, Cleaning the ABS sensors etc. Checked the Fluid levels and all ok. Going to remove the sensor and clean it tomorrow. I also have a slow puncture. Which takes over 2 weeks to drop 10psi. So i don't think that is affecting it but its on the list to get fixed. |
01-01-2016, 02:51 PM | #5 | |
24
Rep 92
So I scanned the car for faults again tonight and its throwing up a Steering Sensor Fault. |
01-02-2016, 05:16 AM | #9 |
24
Rep 92
