BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > Retrofit Paddles | Help Needed
      12-27-2015, 05:17 AM   #1
4sauto
Drives: 530d F10
Hi,
I ordered a M sport steering wheel (with Paddles) to install it on F20 LCI 118d (without paddles).
Is there an additional harness needed to make the paddles work?
Also, what is the coding procedure using E-Sys?
Thanks in advance..!
      12-29-2015, 05:56 AM   #2
yalim7
[HOONIGAN]
yalim7's Avatar
Turkey
10
Drives: F20 118i-E93 335i
Originally Posted by 4sauto View Post
Hi,
I don't know anything about coding procedure but when doing the same retrofit on my pre-lci f20, i remember the shop added some kind of cable going from passenger's side to steering wheel to make the paddles work. And also you probably need a back cover for paddles to fit in if you don't want to drill a hole in yours.
When you feel like life is passing you by, downshift.
      01-02-2016, 04:26 PM   #3
Skippy1511
Drives: BMW F20 sport 116i
so it is possible.
I was going to buy the steering wheel without paddles but now i might by the msport one with paddles.
when you say drill holes what do you mean?
is yours left hand or right hand drive?
thanks
      01-03-2016, 10:48 AM   #4
yalim7
[HOONIGAN]
yalim7's Avatar
Turkey
10
Originally Posted by Skippy1511 View Post
so it is possible.
thanks
With some coding and the cable, yes, it is possible. Mine is left hand drive. By holes, i mean the space needed for the paddles to 'sit' in. You can see them in the attached picture of an m sport steering wheel's back cover. The hole in the red square.
      01-04-2016, 10:28 AM   #5
4sauto
Drives: 530d F10
The steering wheel i purchased it with Paddles. It is the M Sport Steering Wheel.
My car is a RHD..
I need the part # for the cable and the coding procedure.
      04-01-2016, 01:10 PM   #6
Jwood93
Drives: 116d msport
If it helps i bought the steering wheel with paddles, I went to install the cabling but it was already in (2014 116d m-sport)
remove 205 add 2TB to the fa list and recode the whole SVT tree.
Search this Thread:
Advanced Search
